! Message from: vw-widow
Thanks Admin
sicklyorange's D-reg 16v daily - brake problem 12/09/19
Come and show off your ride here!!
sicklyorange
VW Bug
Drives: D-reg 16v
Re: sicklyorange's D-reg 16v - starting problem p15 :(
Postby sicklyorange » Fri Nov 21, 2014 5:59 pm
Anyone know if the thermo time switch is a specific 16v k-jet one or a generic one...?
Struggling to get any websites up at work!
D-Reg VW Golf GTi K-Jet 16v TSR Jade green
Minis
Hairyarse
Dubbin' Crazy
Drives: 93 Corrado VR6
Postby Hairyarse » Fri Nov 21, 2014 8:20 pm
I'm pretty certain they're generic, but check on here - http://www.partsbase.org/vw/eu/
Just find the part on your model then search the part number at the top of the page and it will list all models it's on ;)
1 x
Andy
1983 MK1 Golf GTI Campaign (Resto)
1993 VW Corrado VR6
http://www.yesterdayscars.co.uk
https://www.facebook.com/yesterdayscars
sicklyorange
VW Bug
Drives: D-reg 16v
Re: sicklyorange's D-reg 16v - the ORIGINAL Jade green 16v.... :P
Postby sicklyorange » Thu Jun 04, 2015 8:44 pm
Errrrrr, no updates. Just want people to share the recent love for D-reg Jade green 16valvers
:mrgreen:
Minis
Damien.wrl
Site Admin
Drives: an armchair
Re: sicklyorange's D-reg 16v - the ORIGINAL 16v jade green.... :P
Postby Damien.wrl » Thu Jun 04, 2015 9:12 pm
A lot of love for them at the moment ......
1988 Alpine White 35k mile OCD MK2 GTi ".................. viewtopic.php?f=12&t=128
eddypeck
Supercharged
Drives: 1991 MK2 Golf GTI 8v
Contact:
Postby eddypeck » Fri Jun 05, 2015 9:19 am
Damien.wrl wrote:A lot of love for them at the moment ......
Nah, they're too common :lol: Only kidding, much jealously from this corner! I think early jade green 16v has to be my fav combination.
sicklyorange
VW Bug
Drives: D-reg 16v
Re: sicklyorange's D-reg 16v daily
Postby sicklyorange » Sun Sep 20, 2015 12:42 pm
Ok, need help guys...
This cold starting problem is really annoying me now. Hot starting is fine.
The car is getting into cold season and not wanting to start 'easily':
It needs cranking over and over to start. It seems to help if I have my foot flat on the accelerator. It coughs into life but then hunts and I have to hold it steady on the throttle for 20secs or so. Then it's perfect and runs fantastically.
Things that have been replaced due to leaks:
Main pressure pump, plastic tank, accumulator, fuel filter.
Things that have been checked:
Cold start valve is firing when cold, so all associated systems for that are good,
Fuel pressure has been checked - control pressure and system pressure both spot on, so WUR and associated systems good.
CO2 is at 1.64%.
Spark plugs/dizzy cap and rotor all replaced when serviced.
There will have been other things I've done and maybe forgotten about.
HELP!
Minis
eddypeck
Supercharged
Contact:
Postby eddypeck » Sun Sep 20, 2015 11:46 pm
I would still suspect wur? I know how frustrating this is, hope you get it sorted. I've got a reset pdf I'll sort out a link for you.
1 x
sicklyorange
VW Bug
Drives: D-reg 16v
Postby sicklyorange » Thu Sep 24, 2015 10:34 pm
Going to try another WUR tomorrow.
Looks as though someone's been at it - the 4socket screws and bolts have all been replaced with quality st/st items...
Back's not been drilled so I may do that before I put it on.
Minis
sicklyorange
VW Bug
Drives: D-reg 16v
Postby sicklyorange » Sun Sep 27, 2015 9:53 pm
Better get some old updates on here while I have a chance...
The reason why the tyres were scrubbing so much:
2 degrees toe out!
Tried polishing up the exhausts and I am very pleased
Cool!
Also got some LED dash lights and complimentary Haribo!
Got some stainless steel sunroof deflector arms
A bargain from someone on here
WUR - drilled out for future mods by me but stainless screws and bolts are a mystery....?
Still no change in today's cold starting but I notices that some of the rubber tube connections were a little loose so I fitted jubilee clips to them and we'll find if it's made any difference tomorrow.
Night-night!
Minis
sicklyorange
VW Bug
Drives: D-reg 16v
Re: sicklyorange's D-reg 16v daily - top mounts and brake pads
Postby sicklyorange » Wed Jun 01, 2016 9:46 pm
Evening all,
One of the top mounts is rattling like mad when the wheel is of the ground.
Can't remember what is recommended to replace the standard ones with - is it the G60 ones? Where from- GSF, VW Heritage? VW Spares?
Also are people still using green stuff pads (on the front) or are there better alternatives these days?
Thanks in advance, :)
Rich
Minis
Return to “Members Rides”
Users browsing this forum: No registered users and 8 guests
