! Message from: vw-widow
Thanks Admin
1991 MK2 GTI 20V Pearl Grey - Work In Progress
Come and show off your ride here!!
Challice 16v
OEM
Drives: Mk2 golf gti 16v
Re: 1991 MK2 GTI 20V Pearl Grey - Work In Progress
Postby Challice 16v » Sat Sep 29, 2018 11:09 am
That looks sooooo good.
Don't sell it you will regret it as soon as it drives off with the new owner...you will want to chase after it waving the cash shouting noo take the money back...
1 x
DoubleOSeven
OEM+
Drives: 1990 1.6 CL AUTO
Postby DoubleOSeven » Sun Sep 30, 2018 11:36 am
I’m seeing prices plateau now and had to work had to sell my last one. I got £7k for my Oak Green with original engine 170k if that helps, but I think I got lucky tbh. I’d keep it if I were you, as you maybe disappointed what you get offered for it. Most were offering around £5k.
1990 CL 1.6 Automatic
Monkey
Site Admin
Drives: VWs, lots of them!
Contact:
Postby Monkey » Sun Sep 30, 2018 7:11 pm
Don't sell it mate! You will definitely regret it, I certainly did!
Keep it and develop it.
Remember, if you fancy a change, you can always stick a different engine in :wink:
Mk4 Anni Derv
Mk2tom
L-Driver
Drives: 1988 CL Jade Green
Postby Mk2tom » Fri Oct 12, 2018 8:33 am
Stunning car that is you've done a great job with it! Good inspiration for me to push on with mine.
Couldn't imagine selling mine after putting in all the hard work, not unless someone offered me silly money!
Sent from my Pixel 2 using Tapatalk
cupracraig
VAG Monkey
Drives: 1.8 20v Turbo
Postby cupracraig » Fri Oct 12, 2018 11:45 am
ive gotten back into model plane flying and just invested a load of money back into it including loads of FPV gear and a racing drone. The golf can just stay int he garage all winter and keep dry while i make a decision on it
cupracraig
VAG Monkey
Postby cupracraig » Thu Nov 29, 2018 12:52 pm
did a little something different to get away from the Golf for a while - excuse the mess
ImageIMG_20180916_101703 by Cragmire40D, on Flickr
nearly done:
ImageIMG-20181124-WA0000 by Cragmire40D, on Flickr
cupracraig
VAG Monkey
Postby cupracraig » Tue Jan 29, 2019 3:00 pm
time to get back ont he car after it just sitting in the garage all winter.
First job is to replace the cam cover gasket, its failed on the rear and caused a bit of an oil leak which the MOT tester picked up on. ive been cleaning up the cam cover in order to paint it crackle black while im there.
i looked into fitting R8 coilpacks but you cant do it on the older AGU engines due to the wire harness. Its alot more work to splice in the new loom elements which doesnt bother me, but not at this time of year when i want to start driving it.
the cams are in great condition! and after cleaning up the mating faces, its looking ready to go back together with new gaskets.
cupracraig
VAG Monkey
Postby cupracraig » Mon Feb 11, 2019 10:20 am
Another busy weekend pushing on with the car.
Finished cleaning up the cam cover, masked up ready to paint
Idle pulley bearing was rough so took that apart, cleaned up all the aluminium, chemically treated it and then cleaned again and clear coated it... i also did this with the bracket on the front of the engine for the alternator
Took the bearing out thinking i could just replace it... looks like its easier to just replace the assembaly
Stripped the alternator to check the bearings as it sounded a bit gritty..
Outer shaft bearing in the casing is all good... inner is gritty..Part number for it in pic. ordered a new bearing and will replace that.
did loads more cleaning up of the alternator casing, i will clear coat this when done.
and put some of it back in to get an idea of how its looking.
1 x
Monkey
Site Admin
Contact:
Postby Monkey » Mon Feb 11, 2019 3:16 pm
It reminds me of those partly stripped engines you see in museums!
Mk4 Anni Derv
cupracraig
VAG Monkey
Postby cupracraig » Tue Jul 09, 2019 11:20 am
keeping the thread alive...
ImageIMG_20190506_210351_312 by Cragmire40D, on Flickr
1 x
Return to “Members Rides”
Users browsing this forum: No registered users and 6 guests
