Unable to set up MK2 GTI 8v
Is your car playing up? Section includes conversion advice, temperature control, ECU and ignition problems.
Dublife
OEM
Drives: 1991 mk2 Golf GTi 8v
Postby Dublife » Mon May 13, 2019 12:44 am
Hi all,
My 91 gti 8v is having running issues, when cold its rough and wont rev clearly for a minute, then once warmed up, it feels like its misfiring under load. Unless i really floor it and it sometimes clears and goes (but still feels underpowered)
Replaced:
Lift pump as it was shot
Genuine blue temp sensor
Spark plugs
Plug leads
Dizzy cap
Rotor
I noticed the adjuster at MAF for the CO was fully screwed in so thought i'd try rubjonny's guide to setting up CO and idle, but when i get to the 'rev 3 times over 3k stage', it wont rev at all, itll either splutter its way up the revs or just cut out.
Any ideas?
Thanks for reading
Sent from my SM-G960F using Tapatalk
eddypeck
Supercharged
Drives: 1986 MK2 Golf GTI 8v
Re: Unable to set up MK2 GTI 8v
Postby eddypeck » Mon May 13, 2019 7:31 am
I don’t have much experience with digi, but as you seem to have covered everything else could it be isv?
Online
DaveST
OEM
Drives: 1990 Golf GTI 8V 3dr
Postby DaveST » Mon May 13, 2019 7:32 am
Have you checked the engine and ignition timing?
These really need to be spot on before adjusting the CO.
Dublife
OEM
Postby Dublife » Tue May 14, 2019 1:31 pm
Cheers for the replies,
Yeah the isv is all good but im gonna check the ignition timing too
Rich
Dub Ninja
Drives: moped.
Postby Rich » Tue May 14, 2019 5:03 pm
Compression test.
Poverty spec member.
Avid follower of EddiePeck's lunchtime project.
Return to “Engine & Gearbox”
Users browsing this forum: No registered users and 9 guests
