Throttle cable snapped. What do i need?
Is your car playing up? Section includes conversion advice, temperature control, ECU and ignition problems.
wlsmith1985
OEM
Drives: 1992 MK2 Golf GTI 20VT
Postby wlsmith1985 » Fri Jun 28, 2019 9:40 pm
Hi guys
Today my throttle cable snapped at the pedal end. Its a mk2 golf gti it was originally an 8v but its running a 1.8turbo 20v agu engine. Do i need a mk4 cable or do i need a mk2 cable? Can someone point me in the right direction. Bought the car like it so not a clue
Kind regards
Will
Kenneth cartwright
OEM+
Drives: 1989 gti valver
Re: Throttle cable snapped. What do i need?
Postby Kenneth cartwright » Sun Jun 30, 2019 11:37 am
hi, sorry just seen this, can you remove cable? to identify parts number? if in doubt take both ends to autofactors and a tape measure.. but would think agu cable would be the 1, and just to route it as found
:jackson:
On the drive mk1 cabbies and mk2 gti valver.
wlsmith1985
OEM
Postby wlsmith1985 » Wed Jul 03, 2019 8:38 am
Hi Kenneth
I got it sorted, for those who wish to know if you are running the AGU engine you need the longer throttle cable from the 1.3 carb model I think its the 1364mm one (longest they do)
Kind regards
Will
Return to “Engine & Gearbox”
Users browsing this forum: No registered users and 4 guests
