Coolant from oil cooler
Is your car playing up? Section includes conversion advice, temperature control, ECU and ignition problems.
Tracee
OEM
Drives: 1991 MK2 golf 8v gti
Postby Tracee » Sun Oct 06, 2019 9:12 am
My MK2 golf GTi 8v pb appears to be leaking externally from the oil cooler. Feels like it's coming from the corner of the cooler. Is this possible?
I've just about had enough of this car!!! Anyone wanna by a 54k 3 door!
Sent from my FIG-LX1 using Tapatalk
Tracee
OEM
Re: Coolant from oil cooler
Postby Tracee » Sun Oct 06, 2019 9:26 am
Tracee wrote:My MK2 golf GTi 8v pb appears to be leaking externally from the oil cooler. Feels like it's coming from the corner of the cooler. Is this possible?
Leaking coolant externally not oil.
Damien.wrl
Site Admin
Drives: an armchair
Postby Damien.wrl » Sun Oct 06, 2019 6:31 pm
Can’t help with the fix but a well sorted mk2 can be better than a five year old box of electronics on wheels
1988 Alpine White 35k mile OCD MK2 GTi ".................. viewtopic.php?f=12&t=128
Monkey
Site Admin
Drives: VWs, lots of them!
Contact:
Postby Monkey » Mon Oct 07, 2019 10:20 am
The oil cooler is a water based system, it's probably just failed, pretty common, especially due to the age of the car.
They're actually pretty cheap...
https://www.vwheritage.com/068117021b-o ... jAQAvD_BwE
Mk4 Anni Derv
eddypeck
Supercharged
Drives: 1986 MK2 Golf GTI 8v
Postby eddypeck » Mon Oct 07, 2019 1:15 pm
Cheap and a fairly easy fix. Like most things on these cars doesn't cost a lot to do and can be done with some basic tools (unlike the 5 year old box of electrics mentioned above). I guess the problem is when all these simple, cheap fixes add up it give the appearance of never ending issues and continual cost. But look at it this way, if it's failing after 30 years and the fix is £30, suck it up get it done and cross it off the list of things you won't need to do again. Eventually you'll have replaced everything :D
Tracee
OEM
Postby Tracee » Tue Oct 08, 2019 7:32 am
eddypeck wrote:Cheap and a fairly easy fix. Like most things on these cars doesn't cost a lot to do and can be done with some basic tools (unlike the 5 year old box of electrics mentioned above). I guess the problem is when all these simple, cheap fixes add up it give the appearance of never ending issues and continual cost. But look at it this way, if it's failing after 30 years and the fix is £30, suck it up get it done and cross it off the list of things you won't need to do again. Eventually you'll have replaced everything :D
Yep you're right so far
Service kit plugs, oil and filter air filter, full set of wiper blades.
Both fuel pumps and all fuel lines.
ALL brake lines both Flexi and solid. Brake disc, pads, bearing, caliper carriers and bolts all round.
New sump pan and gasket, cleaned out pick up whilst I was there.
New top mounts
All new drive belts
New tyres all round
New coolant pipes
And now oil cooler
I've done it all myself plus working full time.
Just getting frustrated, booked the MOT but had to cancel it cos it sprung a leak!!
I went and got the parts yesterday. Do I need to drop the oil from the sump? Or can I just remover the oil filter?
Thanks for the words of encouragement
On the upside I haven't found I speck of rot
Monkey
Site Admin
Contact:
Postby Monkey » Tue Oct 08, 2019 9:02 am
You'll only have to drop the oil from the filter and the cooler.
But you'll loose a fair amount of coolant too, so be ready for that.
I'd take the pipes off the cooler first, then let the coolant drain out.
Once that's stopped get an oil catcher under and take off the filter.
Once that's off, it'll expose a nut on the threaded pipe (that you screw the filter on to).
Take that off and the cooler will drop off.
I'd also get a new o ring for it when you refit the new one :thumbs:
Mk4 Anni Derv
Tracee
OEM
Postby Tracee » Tue Oct 08, 2019 11:28 am
Yep all done, took about an hour start to finish. I f*ing hate those hose clips (just needed to vent that)
It's started to pour down so just having a cuppa whilst that passes then back out and see if we have cured the issue
1 x
sly_gti
VW Bug
Drives: Mk2 2.0 8v
Postby sly_gti » Tue Oct 08, 2019 11:44 pm
Get your self some hose clip pliers and there easy to remove.
Mine cost me about £8
Tracee
OEM
Postby Tracee » Wed Oct 09, 2019 7:47 am
sly_gti wrote:Get your self some hose clip pliers and there easy to remove.
Yeah I have a set, they do make it easier, but I still dislike them!
Anyway, all done just going out to double check everything on the car is torqued up today.
And, finally it's MOT time (first in one in 8 years for this car)
Thanks for help,
Appreciated as always.
Return to “Engine & Gearbox”
Users browsing this forum: No registered users and 9 guests
