1980's / 90's Votex Steering Wheel + Small Spline Hub
Got some bits lying around, or a whole Mk2 to strip apart? Stick an ad in here!
bacardincoke
OEM+
Drives: 1992 MK2 8v
Postby bacardincoke » Mon Mar 11, 2019 9:04 pm
Genuine, period 1980's / 90's high quality 'Votex' branded black leather steering wheel (center pad is also leather covered).
Made for Volkswagen by Atiwe of Italy, and based on their ATC4 model.
Diameter is approx. 36.5 cm, with a very slight dish.
The hub, (number 1729X) is also a genuine period Atiwe item to their unusual 3 bolt pattern.
It's dated 1988 and retains it's original VW horn ring.... it's intended for small spline steering column Volkswagen models from that era.
This includes, but is not limited to most MK1 and early MK2 Golfs / Corrados and some Porsches, however it is important that you ensure it is correct for your vehicle before bidding as there is always the potential for variations between models (Google Atiwe 1729X).
A genuinely scarce wheel made all the more so by having it's correct and arguably even more scarce hub.
Wheel and hub are both in very good condition. Stitching is tight and straight with no loose or frayed ends on the wheel, the hubs rubber sleeve is undamaged and flexible.
The original leather on the wheel and pad is soft and supple with no cuts or snags, though being at least 30 years old please allow for some age related patina.
Both horn buttons work correctly.
The center pad is secured using 4 x knurled screws on its rear face, one is missing however the remaining three hold it rock solid. I'll include an additional correct sized but non-standard screw should you want to use it.
(If you're on a PC, right click and use view image option to magnify some of the pics.)
Paypal which includes Royal Mail tracked / insured and signed for postage to a standard UK address.
bacardincoke
OEM+
Drives: 1992 MK2 8v
Re: 1980's / 90's Votex Steering Wheel + Small Spline Hub
Postby bacardincoke » Thu Mar 14, 2019 12:43 pm
bacardincoke
OEM+
Drives: 1992 MK2 8v
Postby bacardincoke » Thu Mar 14, 2019 12:44 pm
bacardincoke
OEM+
Drives: 1992 MK2 8v
bacardincoke
OEM+
Drives: 1992 MK2 8v
Postby bacardincoke » Thu Mar 14, 2019 12:45 pm
Drives: 1986 MK2 Golf GTI 8v
Postby eddypeck » Thu Mar 14, 2019 1:16 pm
That's very smart and looks in great condition GLWS
Return to “Mk2 Parts For Sale & Breaking”
