1991 16v - 2nd time owned - Restoration
Come and show off your ride here!!
Fish4
Drives: Just bought MK2 16v
Re: 1991 16v - 2nd time owned - Restoration
Postby Fish4 » Mon Feb 25, 2019 10:14 pm
Only surface rust so gave it a good sanding and a couple of coats of Hydrate 80. Sprayed it with some Satin black metal paint Image
Sent from my iPhone using Tapatalk
Fish4
Postby Fish4 » Tue Feb 26, 2019 3:36 pm
And fitted back on the car with a new master cylinder, looking much better. Took the drivers seat out this time to make things a bit easier to fit the nuts up behind the pedals. Image
Fish4
Postby Fish4 » Tue Feb 26, 2019 3:38 pm
Any tips for getting the brake reservoir into the master cylinder? I know it ‘pushes in’ but hell it’s tight! Tried a bit of brake fluid as lube but still no joy.
Rich
Dub Ninja
Drives: moped.
Postby Rich » Tue Feb 26, 2019 4:34 pm
Did you remove the yellow caps?
Poverty spec member.
Avid follower of EddiePeck's lunchtime project.
Fish4
Postby Fish4 » Tue Feb 26, 2019 4:36 pm
Er, Yes
Fish4
Postby Fish4 » Tue Feb 26, 2019 8:37 pm
Brute force was all that was required Image
Fish4
Postby Fish4 » Sat Mar 16, 2019 9:58 pm
Seeing as the engine is out I thought I’d take a look at the inner CV joints...a touch worn after 179k Image
Coakers
Drives: 1987 MK2 Golf GTI 16V
Postby Coakers » Tue Mar 19, 2019 5:39 pm
Keep the updates comin!
Return to “Members Rides”
Users browsing this forum: No registered users and 9 guests
