Oldbie
Talk about anything! (But keep it clean please!)
DoubleOSeven
OEM+
Drives: 1990 1.6 CL AUTO
Re: Oldbie
Postby DoubleOSeven » Wed Oct 30, 2019 3:11 pm
On top: Grey Thermoswitch = Manifold / Carb. Heater 251 919 369B
On top: Red Thermoswitch = Thermal Switch for Auto Start / Inlet Heater 191 919 369B
Underneath: Black Sensor = Temp. sensor for coolant / dash guage 251 919 501D
1990 CL 1.6 Automatic
rickygolf83
VAG Monkey
Drives: 8v, 16v, mk4 1.8t, mk4 td
Re: Oldbie
Postby rickygolf83 » Fri Nov 01, 2019 12:54 am
Dont know much about carbs, got my 1st carb car in 2017 and can do the basics lol
There is an FAQ for your 2e2 carb on golfgtiforum
http://www.golfgtiforum.co.uk/index.php ... ic=18871.0
Bound to be a hot start related post on there.
Some well known vw forum gurus have posted on it, definitely worth having a read
Sent from my SM-G950F using Tapatalk
DoubleOSeven
OEM+
Re: Oldbie
Postby DoubleOSeven » Fri Nov 01, 2019 1:22 pm
Thanks for that - I will test the Thermoswitches by immersing them in boiling water, with a Multimeter across the pins. Should go open cct when hot, it says.
DoubleOSeven
OEM+
Oldbie
Postby DoubleOSeven » Sat Nov 02, 2019 10:22 pm
The red thermoswitch had 2 ohms and when placed in boiling water changes to open cct. I bought a new one and it operates in the same manner. Not convinced therefore this is the issue. Road test tomorrow.
DoubleOSeven
OEM+
Re: Oldbie
Postby DoubleOSeven » Thu Nov 07, 2019 9:24 pm
Had a thought. On a previous non start when hot I sprayed carb cleaner directly into carb. This would have sat on the pistons and fired when ignited. It started, but this is essentially a ‘bump start’ for an auto, not because it was running lean. It doesn’t just become lean because it’s hot.
So, I wonder - when hot the solenoid is getting stuck and therefore not engaging the fly wheel. I can hear the starter spinning, so this put me off thinking it was the starter initially.
Think I’ll fit a new starter if tomorrow’s road trip is unsuccessful. Might outsource this job, if a starter motor swap on an auto is a bit of a ‘mare?
DoubleOSeven
OEM+
Re: Oldbie
Postby DoubleOSeven » Thu Nov 07, 2019 9:54 pm
Either that or fit hot solenoid.
Hot solenoid, so 1st takes the voltage and doubles it and passes it on to starter solenoid switch fires with gusto
rickygolf83
VAG Monkey
Re: Oldbie
Postby rickygolf83 » Thu Nov 07, 2019 9:55 pm
Shouldnt be much if any harder than on a manual mk2 i'd imagine
The starter bolts screw through the front engine mount. Support the engine from the sump/bell housing on a jack with block of wood to distribute the load.
You may have to raise the engine via this jack to line the bolt holes up when fitting new starter
What makes you think starter is at fault? I had an issue starting and it was dodgy battery cable; excessive resistance
DoubleOSeven
OEM+
Re: Oldbie
Postby DoubleOSeven » Fri Nov 08, 2019 12:51 pm
I think you may be onto something with the high resistance - especially when hot.
I only suspected the solenoid / starter through another car scenario. Starter does spin freely hot or cold.
rickygolf83
VAG Monkey
Re: Oldbie
Postby rickygolf83 » Fri Nov 08, 2019 4:37 pm
I only found out about mine after the engine bay had been powerwashed and steam was rising from the cable as it struggled to start.
The cable was absolutely roasting to touch
DoubleOSeven
OEM+
Re: Oldbie
Postby DoubleOSeven » Fri Nov 08, 2019 7:08 pm
Adjusted air/fuel mixture (more rich/clockwise x5 turns). Started on the button/hot.
Return to “General Chat”
Users browsing this forum: No registered users and 13 guests
