Boot central locking mechanism
If your question doesn't fit in above, come on in!
Pingman
Drives: 89' 16v CE1
Re: Boot central locking mechanism
Postby Pingman » Wed Apr 10, 2019 9:17 pm
Yeah I was pondering that too, possible one of these could work
https://www.ebay.co.uk/itm/113355564699
Online
Pootz
VW Bug
Drives: A 5 door Shed
Postby Pootz » Wed Apr 10, 2019 9:19 pm
Would only work if the spigot holding the arm on is hollowthough for it to fit down
Pingman
Drives: 89' 16v CE1
Postby Pingman » Thu Apr 11, 2019 9:35 pm
Pootz wrote:Would only work if the spigot holding the arm on is hollowthough for it to fit down
I don't think you could do it with the standard wiper mount as the splined part is rather thin and is only held on with a small nut, not enough material to bore out. :(
I'm just going buy a standard spray unless I can identify a misting type one to go in it's place.
Online
Pootz
VW Bug
Postby Pootz » Thu Apr 11, 2019 9:43 pm
I was looking for one that's already got it built in that would possibly fit the mk2 as a replacement but had no joy. Not sure what mechanism would fit in place of standard one
Sent from my SM-A530F using Tapatalk
Online
Drives: 1986 MK2 Golf GTI 8v
Postby eddypeck » Fri Apr 12, 2019 7:40 am
From owning mk4 golf and Audi A3 the central spray is not all that and they present their own problems.
Plus every can I can think of that has it has the wiper mounted straight into the glass. Without modifying and potentially some remanufacturing (maybe ok if you have a 3D printer) I just don’t think it’s worth the effort. But if you want to try it any VAG car for the last 20 years shares pretty much the same set up with the only real difference being length of arm, so plenty of donors in scrap yards.
Online
Pootz
VW Bug
Postby Pootz » Mon Apr 22, 2019 1:15 pm
Finally fixed my wiper..earth wire had broken so just it and fitted a new length. Washer jet still not working though
Return to “Other Technical Problems”
