Rear suspension
Tyres, Camber, Caster and Toe, Wheel Offsets, Power Assisted Steering questions all in here please
AWmk2cl
L-Driver
Drives: 1987 Golf CL Auto 1.6
Rear suspension
Postby AWmk2cl » Wed Oct 16, 2019 7:38 pm
Hi everyone, had a knocking/rattle coming from the rear shock top mounts, I knew the old shocks were knackered so I bought new ones, I've also changed the top mounts for new, the spring plates are not rotten, put it all back together making sure everything is as it should be, the knocking is still there, sounds worse at slow speeds.
Any ideas ???
Any help is much appreciated.
Re: Rear suspension
Postby eddypeck » Wed Oct 16, 2019 10:15 pm
Back box on the rear beam is common especially if you’re lowered a bit. Check your exhaust rubbers and hanging brackets.
AWmk2cl
L-Driver
Re: Rear suspension
Postby AWmk2cl » Thu Oct 17, 2019 7:17 am
Cheers mate, it was doing this after I lowered it and it was a heavy knock, i sorted that one out.
This is more of a rattle as if the strut tops are dancing around in there ? Sounds worse coming from drivers side.
Re: Rear suspension
Postby eddypeck » Thu Oct 17, 2019 10:28 am
Ah Ok, thought it was worth considering but if you've already sorted that on onto the next idea.
If it's not the shocks/mounts, then the only other thing in that area would be the filler neck bracket. Not sure if that would be audible, they rot out giving the screw nothing to hold onto so there could be something jiggling around int he rear turret that would sound like it was from the shock area.
Good luck, hope you sort it.
AWmk2cl
L-Driver
Re: Rear suspension
Postby AWmk2cl » Thu Oct 17, 2019 1:39 pm
Cheers mate, I'll look at that next, many thanks.
AWmk2cl
L-Driver
Re: Rear suspension
Postby AWmk2cl » Thu Nov 07, 2019 11:31 am
Hi, it wasnt the filler neck bracket so the search continues, definitely worse on the drivers side, it doesn't affect the handling, tho it's got less guts than a mobility scooter so doubt that will become a problem lol
If I ever find out what it is I'll post it up !!!
Thanks again for the help.
sly_gti
VW Bug
Drives: Mk2 2.0 8v
Re: Rear suspension
Postby sly_gti » Thu Nov 07, 2019 5:26 pm
Are the parcel shelf supports all screwed down properly?
Mine use to squeak a bit.
Re: Rear suspension
Postby eddypeck » Fri Nov 08, 2019 1:13 pm
not anything lose in the spare wheel well.... a locking wheel nut adapter rolling around or anything daft ?
Return to “Wheels, Suspension, Steering”
Users browsing this forum: No registered users and 3 guests
