What Coolant to use
Is your car playing up? Section includes conversion advice, temperature control, ECU and ignition problems.
What Coolant to use
Postby eddypeck » Tue Oct 22, 2019 12:08 pm
I'll soon be doing a new thermostat and heater matrix so will flush the whole system. So what coolant can/should I put back in.
I gather as long as it's flushed then anything as mixing is the main problem, the bit on the side of the expansion bottle says G11.
Looking online there's so much choice now I'm unsure on where to start, G11, G12, G13, G13+, AG13+ and every other number up to G48 I think.... all readily available in lots of different colours and the majority of stuff appears to be pre-mixed and ready to use.
Looking for kind words of wisdom please :eh:
Monkey
Site Admin
Drives: VWs, lots of them!
Re: What Coolant to use
Postby Monkey » Tue Oct 22, 2019 12:50 pm
Depending on what's available, I usually stick in G12/13.
But I have been into Halfords and picked up their stuff before out of desperation and never had an issue.
Mk4 Anni Derv
Postby eddypeck » Tue Oct 22, 2019 2:43 pm
Return to “Engine & Gearbox”
