| Author |
Message |
kevinkevin
Posted:
Sat Jul 31, 2010 12:38 pm |
Hello There,
I recently bought a 1.3 Ryder, The release bearing is on its way out so thought I might as well replace the whole clutch. Is it worth taking it to Mr. Clutch to do a replacement with a 20k or 2 yr warranty for 135 or how hard is it to sort it out myself?
Thanks in advance. |
dana
Posted:
Sat Jul 31, 2010 2:54 pm |
I think that's pretty reasonable! I'd go with that rather than trying yourself. The clutch will be about £60 so you'll only paying about £65 labour. Plus you have the safe knowledge it's under warranty! |
kevinkevin
Posted:
Sat Jul 31, 2010 3:36 pm |
thanks for the reply, I can't seeing it being too much effort for them, it's only a 1.3, there is plenty of room in the to work with. |
white_spanner_animal
Learner Driver
Posted:
Sat Jul 31, 2010 11:54 pm |
the release bearing can be changed without removing the gearbox itself and can be changed in about 30mins at a guess, and may not even be changed as part of a clutch removal and change, however 135 is a reasonable price otherwise |
kevinkevin
Posted:
Sun Aug 01, 2010 11:50 am |
everywhere I've read it mentions removing the box. Do you know where I'd find a guide or what I'd need to do to change the release bearing? |
Learner Driver
Posted:
Sun Aug 01, 2010 2:47 pm |
i oould possibly be wrong, im writing on my experience with 020 box as fitted to the mk2 golfs and the like... part shown below
[img]http://www.performance-cafe.com/popup_image.php?pID=1293&osCsid=106dafe73595180a14afe237d5f48f72[/img]
all you have to do is remove the rear section of the housing nd change the part shown above, it operates a long rob through the gearbox to release the clutch |
kevinkevin
Posted:
Sun Aug 01, 2010 2:53 pm |
Cheers for the info. I've got the 5 speed box in, I'm not sure if this is the original box that it came with when it was made. Do you know how I'd figure out if I have a 020 box? |
Ed
Posted:
Sun Aug 01, 2010 3:32 pm |
You should find the gearbox code on the underside of the bellhousing or it might be written on the inside of the cover of your service manual. |
kevinkevin
Posted:
Sun Aug 01, 2010 3:50 pm |
alsblade
Learner Driver
Posted:
Wed Aug 04, 2010 11:58 am |
hi all,
bit new to this but need some help pls.
have mk2 gti with 1.8 turbo running abour 362 bhp.
did a track day and clutch already gone.
any suggestions for clutch and drive shafts please.
thanks,alan |
kerrly1
Site Admin
Posted:
Wed Aug 04, 2010 12:06 pm |
Kowky
 " alt="" border="0" />
Posted:
Wed Aug 04, 2010 12:14 pm |
Be wary of mr clutch kev as they are quite prone I have heard to giving refurbished parts and charging for new did it for me on one of my old motors had clutch for 5 months and it shattered completely they did replace it under warranty but there's no such luck on the replacement part.was a while ago but just incase |
kevinkevin
Posted:
Wed Aug 04, 2010 3:52 pm |
I've decided to buy the clutch kit myself and then get it fitted at a local garage, they've quoted me 120 for labour.
What clutch kit would you recommend? |
