Dab stereo
Chat about all things Mk2 but not technical questions please
CrazyHorse
Drives: 1988 Golf GTI 16v
Dab stereo
Postby CrazyHorse » Tue Mar 12, 2019 9:53 pm
I want to put a dab head unit in but don't want to go drilling new holes etc. What have others done?
- do dab splitters work off the roof mount aerial (preferred choice)
- I wouldn't mind putting a small one in the windscreen but most I've looked at look quite big and reviews seem hit and miss.
Any other suggestions?
Pootz
VW Bug
Drives: A 5 door Shed
Re: Dab stereo
Postby Pootz » Tue Mar 12, 2019 9:58 pm
CrazyHorse wrote:I want to put a dab head unit in but don't want to go drilling new holes etc. What have others done?
The only ones I've used are the windscreen ones from Halfords but found out that they're less noticeable on the drivers side due to how the wire runs into them. I did think about sticking one either under the scuttle tray or taking the door card off and seeing if I could fit it behind there so it's hidden.
Only other option was run it to the tailgate
Sent from my SM-A530F using Tapatalk
Monkey
Site Admin
Drives: VWs, lots of them!
Re: Dab stereo
Postby Monkey » Wed Mar 13, 2019 9:52 am
It's not the cheapest, but you can get the bee sting aerials that are both analogue and DAB, apparently they are also the best for signal too.
I was considering this, before I decided to just use my phone to stream the radio.
Mk4 Anni Derv
CrazyHorse
Re: Dab stereo
Postby CrazyHorse » Wed Mar 13, 2019 12:35 pm
I hadn't even thought about the streaming option - that's probably the easiest way.
I'll take a look at DAB bee sting - I presume that will require extra wires running through the roof lining though?
Monkey
Site Admin
Re: Dab stereo
Postby Monkey » Wed Mar 13, 2019 9:53 pm
Yeah it will.
In the end I used a parrot hands free kit to do away with the head unit completely and just run my speakers off my phone.
Used the space to put some gauges in.
Mk4 Anni Derv
Return to “Mk2 Golf Chat”
Users browsing this forum: No registered users and 6 guests
