! Message from: vw-widow
Thanks Admin
Monkeys guide to 1.8ting your mk2
Your source for all guides, instructions and useful info from the old site - please do not post in this section for help
cupracraig
VAG Monkey
Drives: 1.8 20v Turbo
Re: Monkeys guide to 1.8ting your mk2
Postby cupracraig » Tue Apr 26, 2016 12:52 pm
Thought i'd add in my shopping list so far, it might be a good source for people doing the conversion...would also be helpful for people to add to it :party!: This assumes you are going to use an AGU/AQU with either k03 or K03s, you will be splicing the loom yourself and that you are doing the work...so basically...cost only
Part, £, Link
Complete 20v engine, all ancillaries, ECU and wiring to match Donor Car
Drive by wire accelerator pedal and pedal wiring to match 20v engine used Unknown
Diagnostic port to match 20v engine used Donor Car
02J Gearbox Donor Car
Gear shifter and cables to match gearbox Donor Car
Inlet, exhaust, throttle body and turbo gaskets  Donor Car
Assorted silicone hoses an Jubilee and Mikkalor clamps for pipework  Donor Car
100mm Driveshaft cups £90.00 http://www.ebay.co.uk/itm/VW-02J-100mm-1-8T-GEARBOX-CUPS-CONVERSION-MK1-MK2-MK3-GTI-GOLF-20VT-AGU-FLANGES-/162040599403?hash=item25ba5f536b:g:he0AAMXQlgtSv3d8
VR6 clutch from Sachs / LUK / etc with 02a lightened flywheel + Bolts £275.00 Darkside developments
Trackslag downpipe to suit chosen turbo 2.5" £205.00 Trackslag
2.5" exhaust system  £395.00 Trackslag
Front mount intercooler - 550x140 sized with 2.5" inlet / outlet - eBay Special :)  £60.00 Ebay
Mk2 16v radiator  £30.00 Ebay
12" slim-line electric fan  £17.00 ebay
Cambelt kit plus hydraulic tensioner, i.e. Gates kit is well priced and OEM quality  £72.00 GSF
Non-air con auxiliary belt  £10.00 GSF
5W30 oil and proper oil filter i.e. VW / Mahle / Mann  £45.00 GSF
Hydro clutch master cylinder reservoir  £30.00 Ebay
G60/B3/B4 Passat hydraulic clutch pedal box  ?
Master and slave cylinders and lines to match pedal box  ?
G60 rear engine bracket or spaced GTI bracket £26.00 Ebay
G60 Rear Engine Mount (Right) £38.95 https://www.vwheritage.com/shop/535199262/engine-mount-rear-mk2-golf-corrado-16v-g60-1988-hydro-moun/?gclid=Cj0KEQjwo_y4BRD0nMnfoqqnxtEBEiQAWdA128THUawxusVjL9YqSChIePeS4Qr3uRSGsi1T16NNsRUaAnGB8P8HAQ
G60 Rear Engine Mount (Left) £12.95 https://www.vwheritage.com/shop/mk2-golf/357199381C/engine-mount-rear-left-mk2-golf-corrado/?crumbStartPage=1&crumbStartRow=1
G60 Front Engine Mount £25.96 https://www.vwheritage.com/shop/mk2-golf/357199279B/front-hydro-engine-mount-gti-16v-g60-mk2-golf-jetta-88-92/?crumbStartPage=1&crumbStartRow=1
02A Gearbox bracket and support bracket * ?
Any Mk2 gearbox mount  Current Mk2
MAP SENSOR RELOCATION TUBE (MADE BY FORGE) £34.72 http://www.forgemotorsport.co.uk/Audi_VW_SEAT_and_Skoda_MAP_Sensor_Mounting_Tube--product--927.html
Any cable change front engine bracket * ?
Mk2 1.3 / 1.6 non-hydro front engine mount  ?
Silicone TIP  £50 http://www.ebay.co.uk/itm/AUDI-TT-VW-GOLF-MK4-1-8T-TURBO-GTI-SEAT-SILICONE-AIR-INTAKE-INDUCTION-HOSE-PIPE-/262021993055?hash=item3d01ba525f:g:J1gAAOSw~uhUnObX
Good quality cone air filter, i.e. RamAir  £70.00
Assorted Silicone pipes (will need to mock up the engine/rad/intercooler first to know) Unknown Ebay
Monkey
Site Admin
Drives: VWs, lots of them!
Contact:
Postby Monkey » Wed Apr 27, 2016 10:18 am
Assorted silicone hoses an Jubilee and Mikkalor clamps for pipework - you'll get very little off your donor car for that.
You'll need to go somewhere like ebay to get the right bends etc, especially around the intercooler.
Mk4 Anni Derv
cupracraig
VAG Monkey
Postby cupracraig » Wed Apr 27, 2016 11:01 am
Monkey wrote:Assorted silicone hoses an Jubilee and Mikkalor clamps for pipework - you'll get very little off your donor car for that.
Added to the list, guess costs and items will only be identified when i mock up the engine with intercooler and Rad in the garage - Pre install
cupracraig
VAG Monkey
Postby cupracraig » Thu Apr 28, 2016 2:12 pm
Found a little link that was helpful for the DBW throttle pedal adaption to the Passat/Corrado hydraulic clutch pedal box
http://www.edition38.com/forums/index.p ... opic=67839
http://www.edition38.com/forums/index.p ... 465&page=4
Return to “Useful Guides, Hints and Tips”
Users browsing this forum: No registered users and 1 guest
