Bonnet Gap Different Each Side Of Wings
Restoring your MK2 back to factory standard, or need advice on getting rid of that spot of rust?
BirdieGTi
L-Driver
Drives: 1990 Mk2 Golf GTi 8v
Postby BirdieGTi » Tue Feb 05, 2019 10:13 pm
Hello, I've got a 90' GTi and as the title says the gap on each side of the bonnet it different, it sits very close to the left and leaves a gap on the right. However its fine height wise and aligments along the top towards the windscreen is fine. Any ideas on ajustability?
Cheers in advance! :bout ye:
:mk2:
eddypeck
Supercharged
Drives: 1991 MK2 Golf GTI 8v
Contact:
Re: Bonnet Gap Different Each Side Of Wings
Postby eddypeck » Wed Feb 06, 2019 3:31 pm
If the gap along the scuttle edge is straight I would say it's more likely the wings have been removed and replaced at some point than the issue being the bonnet alignment.
Slacken off the 10mm bolts along the top of the wing edges and there should be a bit of movement, enough to allow you to even up the gap.
As a general rule the width of a £1 is quite handy for checking gaps. Slide the coin along the gap, it should move freely without the gap closing up and pinching the coin.
1 x
BirdieGTi
L-Driver
Postby BirdieGTi » Wed Feb 06, 2019 8:14 pm
eddypeck wrote:If the gap along the scuttle edge is straight I would say it's more likely the wings have been removed and replaced at some point than the issue being the bonnet alignment.
Thanks for reply mate, I'll give this ago tomorrow and get back to you.
BirdieGTi
L-Driver
Postby BirdieGTi » Sat Feb 09, 2019 7:43 pm
Tried it today mate, helped out a lot, ill get some pictures tomorrow! cheers
Monkey
Site Admin
Drives: VWs, lots of them!
Contact:
Postby Monkey » Mon Feb 11, 2019 3:22 pm
Generally speaking, if you're aligning the bonnet (and assuming the wings are good) you can use the striker on the bonnet to position it.
Think there a couple of 8 or 9mm bolts on the striker plate, just loosen them, move the plate and nip them back up.
1 x
Mk4 Anni Derv
Return to “Bodywork & Paintwork”
Users browsing this forum: No registered users and 2 guests
