INDICATOR STALK MOD
Beyond factory standard modifications, cosmetic changes and customisation.
Pootz
VW Bug
Drives: A 5 door Shed
INDICATOR STALK MOD
Postby Pootz » Thu Mar 07, 2019 10:00 pm
I am aware that mk3 stalks are a direct swap for mk2 stalks but the large button on the mk3 ones causes a problem...HOWEVER, I've seen these which are described as mk3 stalks and look like mk3 stalks but have a small hazard button like a mk2...can anyone shed any light on these as never seen them before like this.
I have the following information after messaging the seller
Part number on wiper stalk is 6K5 953 503 12254005
Part number on Indicator stalk DOT SAE 0891.
Link to the item on eBay is
https://rover.ebay.com/rover/0/0/0?mpre ... 2978172383
These, being rounder and chunked would be easier for me due to arthritis but don't want to buy them if they won't fit
Thanks
Pootz
VW Bug
Re: INDICATOR STALK MOD
Postby Pootz » Thu Mar 07, 2019 10:19 pm
OK...UPDATE...I've found outbtgatvthese are from a seat inca/ toledo / Cordoba which I'm told are the same fitting as a mk3
Can anyone clarify this as if so then yheybwill fit a mk2
Wayne1983
L-Driver
Drives: 1990 mk2 golf gti abf
Postby Wayne1983 » Sat Mar 09, 2019 4:16 pm
You just need to take the arm off the middle bit of a mk3 stalk with the big switch and put it on a mk2 one. It unscrews off the round bit
Pootz
VW Bug
Postby Pootz » Sat Mar 09, 2019 4:56 pm
Wayne1983 wrote:You just need to take the arm off the middle bit of a mk3 stalk with the big switch and put it on a mk2 one. It unscrews off the round bit
Cheers. I've ordered some from a seat inca now...fingers crossed
Sent from my SM-A530F using Tapatalk
Return to “Modifications”
Users browsing this forum: No registered users and 2 guests
