k-jet head on a 2 litre block
Beyond factory standard modifications, cosmetic changes and customisation.
mhutch
VAG Monkey
Drives: 1990 gti 2.0litre
Postby mhutch » Sun Nov 14, 2010 4:54 pm
ok , i believe skimming the head down to near minimum increases compression? how thick do i leave the head? serious answers please ;)
dannyp
Dubbin' Crazy
Drives: various odball vag clutte
Re: k-jet head on a 2 litre block
Postby dannyp » Sun Nov 14, 2010 8:15 pm
why do you want to increase the compression ? it's plenty as it is, if useing an ABF block it's actualy a bit high as it is. unless some intresting cams are going in then really you cant get the cr high enough with skimming the head
mhutch
VAG Monkey
Postby mhutch » Mon Nov 15, 2010 4:25 am
its an AGG block n a DX head
dannyp
Dubbin' Crazy
Postby dannyp » Mon Nov 15, 2010 11:37 pm
ahh it's 8 valve, there is no point skimming the head to gain cr, you raise it the square root of naff all just skim the head so it's flat if you want to go a bit faster tri cutting the valve seats will help a LOT more
mhutch
VAG Monkey
Postby mhutch » Mon Nov 15, 2010 11:50 pm
excellant , saved me good few bob , pickin up a polished n ported head tomo wi high lift cam n just going to horse it straight in
Return to “Modifications”
Users browsing this forum: No registered users and 1 guest
