Need to throttle to start?
If your question doesn't fit in above, come on in!
Trollepoten63
L-Driver
Drives: 1992 Golf MK2 Rabbit 1.3
Postby Trollepoten63 » Fri May 25, 2018 4:17 pm
Is it normal that I need to give throttle to get my car started, if I don't throttle it doesn't start, it sometimes does start without throttle if the engine has run for a bit. I press my gass pedal down one time to activate the choke then turn the key and give a bit of gass because I have too. What do you guys think what would cause this problem?
It's about a Volkswagen Golf 2, 1.3 with a carburetor
:mk2:
tabbie
VAG Rat
Drives: typ19 gti k-jet
Re: Need to throttle to start?
Postby tabbie » Fri May 25, 2018 4:35 pm
Mine definitely likes a bit of throttle to start, I don't even realise am doing it anymore.
Rich
Dub Ninja
Drives: moped.
Postby Rich » Fri May 25, 2018 4:38 pm
Do a kick down on the pedal, Ie: Floor and release twice in fast succession and then start the car with no throttle.
Then report back.
Poverty spec member.
Avid follower of EddiePeck's lunchtime project.
Trollepoten63
L-Driver
Postby Trollepoten63 » Fri May 25, 2018 4:49 pm
Oh so it's normal to give a bit of throttle. I tried what u said Rich and that doesn't seem to work either
tabbie
VAG Rat
Postby tabbie » Fri May 25, 2018 5:06 pm
Trollepoten63 wrote:Oh so it's normal to give a bit of throttle. I tried what u said Rich and that doesn't seem to work either
If I turn the key through the opened window it definitely doesn't like it and turns over for awhile.
Mine is running a high lift cam which has always made it run like a breathless old fart.
Jump in turn key a little gas and she starts everytime.
Damien.wrl
Site Admin
Drives: an armchair
Postby Damien.wrl » Fri May 25, 2018 5:15 pm
Not sure with carbs but injection should be no throttle
1988 Alpine White 35k mile OCD MK2 GTi ".................. viewtopic.php?f=12&t=128
Trollepoten63
L-Driver
Postby Trollepoten63 » Fri May 25, 2018 5:16 pm
Alright thanks everybody, I guess I'll just have to learn to press the throttle at the right time to start it :D
1 x
tabbie
VAG Rat
Postby tabbie » Fri May 25, 2018 5:20 pm
Damien.wrl wrote:Not sure with carbs but injection should be no throttle
Am not shocked I guess it's my own fault messing around with high lift cams etc. It does sound like a bag of spanners on tick over oooh well.... it does start tho
Georgeydee
L-Driver
Drives: 1987 Mk2 Golf 1.6 Auto
Postby Georgeydee » Thu May 16, 2019 4:53 pm
does your choke flap have a slight gap in it when stone cold? if it's completely closed then this can cause some cold start issues. I adjusted mine so it had a slight gap of 3mm or so and it starts on a single key turn now with no throttle. :party!:
To adjust - back off the 3 screws from the auto-choke housing and twist a little bit.
:mk2:
Return to “Other Technical Problems”
Users browsing this forum: No registered users and 3 guests
