1984 1.3 Golf CL, Fuel/Carb Issue... Please Help
If your question doesn't fit in above, come on in!
k5rlx
L-Driver
Drives: 1984 MK2 Golf CL
Postby k5rlx » Sun Jul 15, 2018 11:36 pm
Small problem hopefully will be an easy fix.
Driving home about 2 weeks ago, about 1/2 a mile from my house the revs died off and the car cut out I managed to get it started again and limped it home. When I got on the drive I left the car running and I could smell fuel really strongly so lifted the bonnet and found fuel leaking from the mechanical fuel pump from this hole.
At this point I stoped the car removed the pump, I ordered a replacement pump and filter and when it arrived I fitted them. I turned the car over a few time and it fired up straight away. I left the car running for around 5 mins and it cut out. When I looked inside the carb it had flooded.
Fitted with a WEBER 32/34 DMTL
I left it over night to dry out, I assumed (this where I think I went wrong :oops: ) that with the old pump on its way out and failing, so the new pump was more powerful and flooding the carb so I adjusted the float then it failed to start I removed the fuel line from the carb and the pump was now not drawing fuel.
I purchased another pump and fitted it, this is pumping the fuel however this is not going into the carb. I have stripped the carb and checked for blocked jets but still no joy. I think I have F**ked something up, when messing around with the float but then again im not really sure it really has me puzzled. :frustration:
Please can someone help me out. If you need more info or pictures please let me know.
Thanks in advance.
Karl.
Return to “Other Technical Problems”
Users browsing this forum: No registered users and 5 guests
