! Message from: vw-widow
Thanks Admin
mk2 golf 3.2 bdb swap
in car entertainment, get the best out of your ICE system also wiring problems, lighting, switches - anything that's not ignition system or ECU related
mk2rich3.2
L-Driver
Drives: mk2 golf 3.2 in the works
Postby mk2rich3.2 » Tue Apr 09, 2019 6:03 pm
in the middle of trying to get the car to run, have the fuel pump working and the engine cranks over fine, cant seemed to keep any spark or to get the injectors to pulse. we checked and replaced the cranks shaft sensor still the same issue, checked to make sure the crank shaft sensor plug was working right and came across 1 earth being the black wire checked seemed to be correct to the diagram and the white and brown wire were both holding 2.5 volts is this normal or is there something not right with ecu/loom i have cheers
eddypeck
Supercharged
Drives: 1991 MK2 Golf GTI 8v
Contact:
Re: mk2 golf 3.2 bdb swap
Postby eddypeck » Tue Apr 09, 2019 9:42 pm
I’d love to help but have no idea?
I’d have a guess at loom/Ecu Though
Hope you get it sorted.
Tommcc
Moderator
Drives: Passat 30v syncro
Postby Tommcc » Tue Apr 09, 2019 10:00 pm
Do you have power to injectors and plugs ?
First thing to check
Next check your loom is all connected and plugged up etc
Check fuses and relays are correct for your conversion
1 x
Jetta soon to be 20vt
mk2rich3.2
L-Driver
Postby mk2rich3.2 » Thu Apr 11, 2019 4:05 pm
Yea I have power at coil plugs and injectors just get no spark no nor do the injector open to allow fuel in, I do have a code that comes up on the diagnostics which is to do with the ecm power relay control circuit low been told that this shouldn’t stop the engine from running that
Monkey
Site Admin
Drives: VWs, lots of them!
Contact:
Postby Monkey » Thu Apr 11, 2019 8:26 pm
The ecm power relay will definitely stop the ecu from starting the engine.
I had that same issue once in a 20v and it turned out to be a fuse gone.
Mk4 Anni Derv
mk2rich3.2
L-Driver
Postby mk2rich3.2 » Thu Apr 11, 2019 9:00 pm
Monkey wrote:The ecm power relay will definitely stop the ecu from starting the engine.
yea did think it could be causing an issues but dont have any fuses gone double checked it so many times been told to make the relay external to the fusebox and take the 3 power from g1/04 g1/08 g2/04 and put the in the 87 of an ignition controlled relay with 30amp fuses on each think this would could help solve the issues cheers for help
Monkey
Site Admin
Contact:
Postby Monkey » Fri Apr 12, 2019 8:11 am
Have you wired it yourself?
If so, did you follow rubjonnys guide?
I did, and it was spot on, very useful
Mk4 Anni Derv
mk2rich3.2
L-Driver
Postby mk2rich3.2 » Fri Apr 12, 2019 2:55 pm
Monkey wrote:Have you wired it yourself?
Had someone do it for me just trying to see if it’s something I done or with it’s his end of converting the looms together
Tommcc
Moderator
Postby Tommcc » Sun Apr 14, 2019 8:33 pm
Who did the loom ?
mk2rich3.2
L-Driver
Postby mk2rich3.2 » Fri Apr 26, 2019 1:46 pm
Tommcc wrote:Who did the loom ?
Company called dudforce
Return to “I.C.E and Electrical”
Users browsing this forum: No registered users and 2 guests
