Page 1 of 1
Votex (Foha) DIN Illuminated Cassette Box... SOLD
Posted: Tue Oct 24, 2017 1:42 pm
by bacardincoke
Made by Foha of Austria and marketed by VW under their Votex accessory brand for the MK2 Golf Votex center console...
The catalogue images are from a 1990 GTi-Engineering brochure, but these cassette boxes have been available from around the introduction of the DIN standard in 1984, so period correct to all age of MK2.
The upper center tab on the front door is spring loaded and when pushed downwards it releases forwards. The door too is spring loaded and when pushed closed engages the tab again.
Holds 6 x un-boxed cassette tapes or can be used as a storage cubby, there being a separate compartment either side of the central spar.
Behind that white upright (to filter the light) is a standard dashboard size bulb.
The bulb should probably be wired to the existing dash lights to come on/off as they do, but not being switched it'll remain on even when the boxes own door is closed.
The box is complete, has all its tabs and the bulb works.
This includes Royal Mail 'Signed For' postage and assumes delivery will be to a standard UK address.
Re: Votex (Foha) DIN Illuminated Cassette Box...
Posted: Tue Oct 24, 2017 7:23 pm
by Damien.wrl
You could have cost me a fortune with the special bits you keep coming up with
Posted: Fri Oct 27, 2017 10:55 pm
by Silvermk2
Sent pm
Posted: Mon Oct 30, 2017 9:47 am
by bacardincoke
Still available...
Posted: Mon Oct 30, 2017 10:18 am
by bacardincoke
Damien.wrl wrote:You could have cost me a fortune with the special bits you keep coming up with
Sorry! MK2 specific stuff... I generally offer it on the Forum first before putting it up elsewhere if there's no takers.
Posted: Mon Dec 11, 2017 3:04 pm
by bacardincoke
Sold...
