Removing thermo w/ Powersteering
Chat about all things Mk2 but not technical questions please
larrytmk2
Drives: BMW 1600-2, MK2 GL
Postby larrytmk2 » Mon Feb 11, 2019 9:10 am
hi guys,
so i set about changing a few bits on the cooling system of the new car, fan switch and thermo was a must.. however i cant actually get to the bolts for the thermostat housing because this cars got powersteering and theres hoses and clamps and brackets in the way.
has anyone else experienced this and if so, how did you get to it?
thanks
Laurence
DeckedMetals - Lowlife Degenerates
Follow > Instagram - Laurence.DKLM
Follow > Instagram - DeckedMetals
Drives: 1986 MK2 Golf GTI 8v
Re: Removing thermo w/ Powersteering
Postby eddypeck » Mon Feb 11, 2019 10:11 am
I can't recall there being an issue. Did the thermostat on mine ages back. From memory, yes there's a bit of stuff in the way, you do need to remove the alternator, alternator mount and drop the PAS pump out of the way but it's not a big deal.
Make sure you replace the thermostat housing when you do the thermostat. They're plastic and tend to warp so never go back on well, treat it as a single use item I think they're less than a tenner. And for the sake of £30 (or there abouts I'm sure) it might be worth sticking a new water pump on there while you're at is.
larrytmk2
Postby larrytmk2 » Mon Feb 11, 2019 10:18 am
thanks eddy, when i was looking at it, i did think i might have to drop the alternator and pas pump out. it makes sense to do it now whilst everythings apart and save having to go back and do it after ive put it all back together!
thanks again
Return to “Mk2 Golf Chat”
Users browsing this forum: No registered users and 10 guests
