1980's GTI-Engineering Italvolanti Formel Steering Wheel... SOLD
Got something that might fit in a Mk2 with a bit of work? Post it up in here.
bacardincoke
Postby bacardincoke » Mon Oct 16, 2017 5:14 pm
Features in the 1983 GTI-Engineering catalogue.
Takes a standard 6 x bolt Italvolanti pattern hub, readily available from all the usual sources both secondhand and new.
Made of very high quality calfskin leather on an aluminium frame in 36 cm diameter. Noticeably fatter rim than a standard wheel
Manufacturing date 28/11/1984.
Not new, but may as well be so… Barely a mark on it save for some very minor rubbing on the rear where the boss meets the wheel… all of which will be hidden when mounted on one again.
The leather is original, soft and damage free.
All stitching is present, tight and straight with no frays or snags.
Silver embossing is flawless, crisp and sharp.
Horn buttons also like new.
The Formel is a genuinely scarce wheel, but in this condition and being one that was marketed by GTi-Engineering it becomes even more so.
Images are of actual wheel and center pad being sold, please inspect them and satisfy yourself as to condition.
SOLD
This includes 2nd Class Royal Mail 'Tracked / Signed For' postage and assumes delivery to a standard UK address.
bacardincoke
Re: 1980's GTI-Engineering Italvolanti Formel Steering Wheel... SOLD
Postby bacardincoke » Wed Oct 18, 2017 10:06 am
Sold...
AndyGTI
OEM+
Drives: 1985 Mk2 Golf GTI 8v
Postby AndyGTI » Wed Oct 18, 2017 3:48 pm
Only just seen this - gutted.
Return to “Other VAG Breaking and Parts”
