Votex Fire Extinguisher (Multi)Holder... SOLD
Got something that might fit in a Mk2 with a bit of work? Post it up in here.
bacardincoke
Postby bacardincoke » Sat Oct 21, 2017 1:51 pm
Genuine Votex Multi-Holder.
Intended to accommodate the mounting of a suitably sized fire extinguisher (with it's own bracket) or the VW First Aid kit (the size you sometimes see fitted to the boot bracket) or a bespoke oddments box... though that last one is difficult to find, lucky you if you've got one!
Designed specifically to fit MKI + MK2 Golf front seats (either side) and possibly other VW's of that era with similar seat frames, though I can't vouch for those.
Hooks around the front bar of the seat frame and is held in place by the clamping action of the 2 x long adjustment screws, so no drilling etc. required and easily removable should you want to take it off again.
Box is tatty, but the contents are new and have never been fitted. All the nuts, bolts, washers etc. needed are present along with fitting instructions in English.
I have to stress... if you're using this for a fire extinguisher, it requires the bracket the extinguisher came with. It's the extinguishers own bracket when attached to the multi-holder that secures the extinguisher.
If you're mounting a first aid box, the long nylon strap in the images secures it to the multi-holder, no other hardware is needed.
Bracket moves back and forth with seat and doesn'tinterfere with seat locking handle.
One of the images is of a period VW accessory catalogue showing this bracket, the catalogue isn't included in the sale.
Some of the other images are of an identical holder fitted to the front passenger seat of my MK2, this is just for illustration purposes - the Gloria extinguisher and it's bracket with red clasp aren't included in the sale
You are buying the holder that is yet to be made up in the remaining pictures.
NOW SOLD
This includes 2nd class signed for postage and assumes delivery will be to a standard UK address.
bacardincoke
Re: Votex Fire Extinguisher (Multi)Holder...
Postby bacardincoke » Mon Oct 30, 2017 9:59 am
Burp...
Return to “Other VAG Breaking and Parts”
