MFA Replacement - VDO Cluster
Your source for all guides, instructions and useful info from the old site - please do not post in this section for help
Jenkiam
L-Driver
Drives: GTi 8v
Postby Jenkiam » Sun Mar 29, 2020 3:48 pm
I've just spent the last few hours removing the instrument cluster from my 92 GTi to replace the MFD, using a v helpful YouTube video, only to find my cluster is different to that shown in the video!! For a start, there was an additional connection at the back of the cluster, next to the speedo cable & the board itself is a single piece, incorporating rev counter & MFD.
I've had a look at the MFD holder & removed the screws securing it to the main board BUT havent been able to remove it easily & dont have the guts to try any harder!
So, is the LCD screen replaceable in these VDO clusters & if so how is the screen holder removed safely?
Jenks
Kenneth cartwright
Drives: 1989 gti valver
Re: MFA Replacement - VDO Cluster
Postby Kenneth cartwright » Sun Mar 29, 2020 6:06 pm
hi do you have pictures of items... from changing LCD on my mk1s i found that can be done but need to take bit more time.. my clipper has wrong display its got MFA rather than clock only and as such does not display anything.. connections different
:jackson:
On the drive mk1 cabbies and mk2 gti valver.
https://www.youtube.com/playlist?list=P ... x_JGYs-zRI
Jenkiam
L-Driver
Drives: GTi 8v
Postby Jenkiam » Mon Mar 30, 2020 11:22 am
...the MFA & the rev counter share a PCB - the white holder does have retaining screws but isnt easily removed & I dont want to force anything obvs!
Kenneth cartwright
Postby Kenneth cartwright » Mon Mar 30, 2020 8:48 pm
:jackson:
Jenkiam
L-Driver
Drives: GTi 8v
Postby Jenkiam » Mon Mar 30, 2020 10:58 pm
Yeah, that's the the vid I watched tbh! His MFA was on a separate PCB to the rev counter so came apart easy.
Kenneth cartwright
Postby Kenneth cartwright » Tue Mar 31, 2020 8:24 am
:jackson:
Return to “Useful Guides, Hints and Tips”
Users browsing this forum: No registered users and 0 guests
