Topic: Heater Matrix / Bulkhead Foam... (Read 1394 times) previous topic - next topic
You'll maybe have read elsewhere I'm in the throws of changing out the heater matrix.
Was going to just reverse the foam gasket affair that seals the 2 x pipes as they pass through the bulkhead but Heritage are doing them so cheaply got one of theirs.
Unlike my original it has a third much smaller hole and it seems to line up with the 'V' channel on the matrix that's on both the original Valeo and the replacement Mahle.
You could very easily run a pipe from the engine area into the cabin using it.
Don't know enough about non-Gti's to recognise if it's there for something I don't have.
Re: Heater Matrix / Bulkhead Foam...
That 3rd hole is for the MK3 recirc flap vacuum tube. Fortunately the heater matrix I got is fine. I haven't seen any similar for sale.
Very clever Mr. Ba...
I put a blob of black Tigerseal in that hole.  Can't see it and nothing is getting in or out.
