Topic: Options for Replacing Radio/CD Player (Read 991 times) previous topic - next topic
Currently I have quite a nice Alpine FM/AM radio/CD player, which I would like to swap for a more modern bluetooth-enabled one, presumably with DAB rather than FM.  Am I right in assuming I wouldn't be able to get one that incorporated CD capability as well, so the whole back unit would need to be changed as well?
Any advice on good units and sources with good service (such as fitting)?  If a new unit was DAB, what does that mean in terms of aerial?  Would I just get rid of the old wing-mounted telescopic one?
Lots of questions, but any advice gratefully received.
Re: Options for Replacing Radio/CD Player
Not sure what you mean about back unit?
If I've understood correctly, you want a head unit with a CD player, DAB and Bluetooth connectivity?
If that's the case, there are plenty of options out there if you just want to buy one, just google something like "Car Stereo CD player DAB" and it'll come up with a selection.
If you want it fitted too, you could go somewhere like Halfords and speak to them, I'm sure they do a fitting service on their kit.
As for the aerial, DAB is slightly different, you can get window mounted aerials that look quite subtle.
You'd still need your wing mounted one if you want to listen to normal radio though.
I have a very nice Kenwood unit in mine which does cd, dab, Bluetooth, fm, also has useful features such as hands free calling and a great selection of audio adjustments to get the best sound from your specific speaker setup. If your not going to fit it yourself would recommend find a trusted local auto electrician, have seen halfords installers make a right mess of changing a lightbulb! Regarding the aerial i have had reasonable success with using  a device called a dab aerial splitter which uses your existing aerial and has a small module that creates a dab and fm signal with the right aerial plugs for each..
88 Gti with ABF and aircon!
Re: Replacing Radio/CD Player
Further to this thread started by me, I have now had fitted a very nice Kenwood unit (maybe same/similar to that mentioned upthread), which is great, but my only niggle is that it will only work when the ignition is on, usually when engine running of course.  My old system worked with the ignition switched off, which meant I could listen to it while parked up, which was ideal.  I don't really understand why the new system is working differently.  Is this just a matter of my getting the installer to switch a lead to supply a feed independent of the ignition?
Yes, it's probably the permanent live and ignition live are switched, usually the red and yellow wire.
