Topic: Mk2 Golf GTi 16v fuel pump housing leak (Read 1583 times) previous topic - next topic
Hi all, I've had to replace the lift pump and the fuel pump / filter in my 16v mk2.
I think the increased flow and pressure has caused a leak to appear the top of the plastic pump housing.
I know that VW stopped manufacturing these so I guess I have two options:
1. See if there is such a thing as a second hand non-leaking housing
2. Buy an aluminium repo at around £450  :'(
Does anyone have any smart ideas, alternatively have experience in doing this? Taking out the housing and pumps etc should be no hassle but some guidance of what to look out for or change whilst doing the work would be great. What clamps to use and what grade and dimeter of hoses etc.
Cheers,
James.
Re: Mk2 Golf GTi 16v fuel pump housing leak
To be honest, I'd probably bite the bullet and go for the ally one.
Any second hand one will be at least 30 years old at this point.
The aluminium one is a fit and forget item and very well made (fitted one to a mates car a few years back).
One other option, while it's a big faff, it might be a little cheaper:
Depending on what you can get, you could potentially fit a mk3 VR6 (or GTI) tank, it's got a fully internal pump setup, however it doesn't have the pressure (if memory serves, VRs are around 3-4 bar, k-jet needs 5). But you could possibly upgrade that pump to suit.
A tank will set you back about £130 and a pump around £100.
Yup, wise words there. Bit the bullet and ponied up for the Pro Alloy housing.
I'm getting new rubber hoses and clips ordered up for the overhaul, but was wondering if you had any advice for the hard lines between the pump, filter and accumulator? Should I look to renew these as it'll all be in pieces or do they hold up OK over the years? The pre-made braided options seem expensive for what they are.
Thanks for your input.
When we did my mates, we reused the originals and they were ok.
But give them a look:
General rule on metal hard lines, if there's surface rust, that's ok, just treat and protect them.
If you can see layers start flaking off, then your lines are loosing thickness and you want to swap them out before you get a failure.
