Topic: Belt or chain  (Read 1259 times) previous topic - next topic
Belt or chain
Did all mk2 engines have belts?
I have a 1.6 CL 4+ E - it’s a very early 1986
I’ve not long had the car but looking at the engine, the cover is a metal one - just wondered if some were chain driven?
Thanks
Re: Belt or chain
Nope, as far as I know, all mk2 engines have belts.
VW only started using chains on the mk3 for the VR engines.
Re: Belt or chain
Crikey, I have a folder of history and no sign of a belt change
Re: Belt or chain
Might want to look into that one!
I highly doubt it's never been done, but definitely pop off the cover and have a look.
See if you can manually wind the engine over until you can see some markings on the belt.
If it's VW marked/there is none and the belt looks worn, the chances are you could be on a wing and a prayer!
Generally speaking, whenever I get a car, I'll swap out the belt if I've got no history/evidence of it being done recently.
For the hundred or so it costs, it's well worth it for piece of mind.
Re: Belt or chain
Thank you and yes, booked in for next Friday for it’s MOT and cambelt
Re: Belt or chain
Original belt
Once every 40 years or 54000 miles
Re: Belt or chain
I have pics but not enough posts yet
Re: Belt or chain
Original belt
Re: Belt or chain
The belt is in remarkably good condition considering- it’s showing signs of splitting!
I will post the pics here when I can
