Topic: 1989 VW Golf Mk2 Syncro + 07K 2.5 Five Cylinder Haldex Conversion Project (Read 695 times) previous topic - next topic
A genuinely  "uncommon"  opportunity that will not come along again. This is a complete, fully researched and largely receipted 07K five-cylinder Haldex AWD conversion project, based on a solid, running, driving genuine Mk2 Golf Syncro. Every major part has been sourced from the right specialists — this is not a box of random bits thrown together, it's a coherent, thought-through build ready for someone to finish.
The Car
1988 VW Golf Mk2 Syncro, silver with correct two-tone grey cladding, F-reg (1989). 5-door. Genuine Syncro — not a conversion. ~78,500 miles on the original VDO cluster. The bodywork is genuinely solid — sills, floors and arches are all clean and rust-free. The only blemish is minor door bottom blistering on the driver's door, completely typical for age. This is not a car hiding structural issues. Runs and drives. Period BBS-style cross-spoke alloys. Twin front auxiliary lights. Towbar fitted. Original plaid cloth interior in good condition. Syncro dash badge present.
MTS Technik Comfort coilover kit (MTSGWVW44-C) currently fitted. Original suspension retained and included — rears were collapsed hence the upgrade.
The Conversion Parts
Drivetrain
2008 VW Jetta 2.5L BGP code 07K five-cylinder engine (110kW/150hp) — correct engine for this swap
Audi TT Mk1 02M six-speed manual gearbox — bell housing already machined/shaved to accept the 07K
07K crankshaft pulley
07K oil filter housing with thermostat
Fabrication & Swap Hardware
Fabless Manufacturing Mk2 2.5L 07K Engine Swap Kit (MK2 factory K-frame / factory width / 4-bolt factory spindles) — the definitive kit for this conversion
Fabless Manufacturing Centre Rad Support Brace (07K)
Fabless Manufacturing MK3 VR6 fan shroud (for radiator)
Fabless Manufacturing MK7 gas pedal adapter (RHD)
Eurowise 07K Power Steering Conversion / AC Delete Bracket
Intake & Engine Dress
IE (Integrated Engineering) 2.5L 5-cylinder Performance Intake Manifold — black finish ($875 new)
IE 2.5L 5-cylinder Billet Valve Cover — raw finish ($495 new)
IE Billet Fuel Rail — black finish
IE Fuel Pressure Regulator Housing — black
IE Vacuum Pump Blockoff Plate
AWD System
DutchBuild Syncro rear beam modified to accept Gen 1 Haldex — professional specialist conversion
Audi TT 8N Mk1 Quattro Gen 1 Haldex rear differential — correct unit for this application
Genuine VW Mk2 Golf Syncro/Rallye rear trailing arms (wider track — correct for Syncro)
2x rear ABS reluctor rings
Suspension & Chassis
VW Mk2 front axle subframe/engine carrier
MK2 GTI steering knuckle + hub + bearing set
VW Golf wheel hub (Febi)
VW Golf wheel bearing kit (Febi)
Kinetix 305mm drilled and grooved front brake discs (4-stud, anti-corrosion coated)
Powerflex Heritage Bushing Kit — complete set specific to Mk2 4WD:
PFR85-260H Rear beam bushes
PFR85-262H Rear trailing arm bushes
PFR85-263-20H G60/Rallye rear ARB bushes
PFR85-264-20H Rear ARB bushes
PFF85-265H Front wishbone rear bushes
Front wishbone front bushes 30mm
Why This Build?
The 07K Haldex Syncro Mk2 is one of the most exciting sleeper builds possible — a completely stock-looking Mk2 Golf hiding a tuneable 150hp+ inline five-cylinder and permanent four-wheel drive. With the IE intake and a tune you're looking at 170-190hp in an 1,100kg car that looks entirely standard. There are very few of these in existence anywhere in the world. The Fabless kit, DutchBuild beam and IE parts alone represent well over £3,000 of specialist components that cannot simply be found on eBay.
Why Is It For Sale?
I'll be honest — I had every intention of building this car, and I think the parts list speaks for itself in terms of how seriously I was pursuing it. Every major component was carefully researched and sourced from the right specialists. Unfortunately a surprise baby means I simply no longer have the time or headspace to run a project car alongside new parent life. Something has to give, and it's not going to be the baby.
Asking £10,000 ONO for the complete package — car and all parts.
Parts will not be split at this price. If no serious interest in the bundle after a reasonable period, parts will be sold individually.
Swaps Considered
Open to interesting part-exchanges — something practical enough for new family life but with a bit of character. Must have Isofix. Happy to discuss top-up either way.
All major purchases are receipted. Viewing strongly encouraged — the car is exactly as shown and all parts are present.
Serious enquiries only. Located in South Gloucestershire.
Re: 1989 VW Golf Mk2 Syncro + 07K 2.5 Five Cylinder Haldex Conversion Project
Huge amount of work gone into sourcing all this, genuinely rare to see a parts list this complete for the 07K/Haldex swap. Real shame you're not getting to finish it yourself but totally understandable with a new baby on the way, that always has to come first.
Couple of questions if you don't mind - is the DutchBuild beam already fitted to the car or still a separate part waiting to go in? And has the 07K engine actually been test run/compression checked, or is it still an unknown from the donor Jetta? Would make a big difference to someone weighing up how much work is left vs just buying a finished car.
£10k for a genuine Syncro shell in that condition plus this parts list still seems fair when you add up what IE and Fabless stuff costs new, just want to get a clearer picture of how "kit of parts" vs "half built" this actually is before anyone drives out to view.
Nice looking project, and a genuine Syncro shell that's rust-free is getting harder to find these days. One thing that would help anyone weighing this up is whether the 07K has any history: mileage on the Jetta it came out of, whether it ran when it was pulled, and if there's any paperwork on the donor car.
Worth noting for a buyer that the 02M TT box and the Haldex setup are the parts that tend to catch people out on a swap like this, so any detail on the condition of the gearbox and the Haldex unit (has the fluid and filter been serviced?) would go a long way. Also curious whether the car is still on the road, and if it's currently taxed and MOT'd, since that affects how easily someone could collect it.
Good luck with the sale, and congratulations on the baby.
