Topic: mk2 golf 1.8T BAM 02m mounts help (Read 172 times) previous topic - next topic
Hello, i need some help regarding engine mounts/brackets on my mk2 golf 1.8T, its a bam engine with a 02m 6speed..
Seems like not many people do a 6speed conversion, all videos on youtube are for o2j's 5speeds and Auq engines etc.
I am using epytec bracket for the gearbox that fits and i am using the standard triple bolt mount for rear , when searching online brackets/mounts for this conversion a single bolt bracket always shows up so i am confused , is the standard triple bolt bracket for rear ok ?
*Note the engine does sit very slightly forward gearbox side by about 2-3cm.. i can't go any further back , the driveshaft of the passenger side wouldn't fit otherwise.
What front engine mount and bracket should i use for the front, seems like there's very little room.
https://postimg.cc/gallery/NsDkWTy/39dd6513
This front mount bracket looks like its not sat on anything apart from the front crossmember , looks like nothings underneath it. (image from ebay epytec)
