Topic: Mk2 golf 8v gti crank no start (Read 275 times) previous topic - next topic
Hi all,
A couple of weeks ago I was getting ready to take my 1988 mk2 8v GTI to a car show. I’ve had the car 3 years and never had any issues with it. I’d left the radio on and the battery was dead so I jump started it and then charged the battery overnight.
The next morning I took off to the car show and got 10 minutes down the road when the car died. It initially fired up again but died again 2 minutes later. Since then it cranks but won’t start.
The fuel pump is still priming and it’s getting fuel. I took the king lead off the dizzy and put it beside an earth point. It’s only getting one spark when I stop cranking and turn the key off.
I’ve tried a new ignition coil which hasn’t changed anything.
Any other tips on other options to try?
Thanks
Re: Mk2 golf 8v gti crank no start
Check how tight your earth cable to the engine is.
If it's loosened off, you could have spiked the ECU.
Thanks for the reply. I’ve already gone through all the earth cables and checked all of them and cleaned them all up.
