Topic: MK2 GTI 8v Start Runs Rich Then Dies and Does Not Want to Start Again  (Read 284 times) previous topic - next topic
I’ve been in the process of restoring a 1986 mk2 GTI 8v CIS Kjet. I have done an excess amount of work on it and after fixing the vacuum leaks I am having trouble keeping the engine running. The list of new parts are listed.
-New fuel distributor
-New fuel lines
-New 5th injector
-New fuel pumps (both)
-New injectors
-New Distributor, wires, and plugs
-New ISV
I have cleaned up the grounds the best I can. Both fuel pumps prime. But I have to wait 24 hours to start the car. After 24hr it starts up quickly it hunts for idle 200-ish rpm for a minute or two and smooths out. The car runs incredibly rich. I pulled the spark plugs and they were caked in carbon from the fuel. I’m at a loss at this point. It’s either the fuel differential module or something else. I’m banging my head against the wall. Each step I take is going to the right direction but I’ve hit a wall.
Re: MK2 GTI 8v Start Runs Rich Then Dies and Does Not Want to Start Again
You've said you've done the Fuel Distributor, but have you done the Warm Up Regulator?
The WUR ultimately controls the fuelling based on how hot the car is, if it has failed, it'll almost certainly cause you massive problems.
You can also try unplugging the 5th injector, these have been known to cause more trouble than they're worth, I run with mine unplugged on my quattro and it starts much better.
I had a similar problem.Turns out the fuel pressure regulator was at fault. Look at the clear pipe that goes to the air box if you can see fuel in it there should not be.
I also can not find the WUR there is a thermo switch for the 5th injector and I have a small Fuel Pressure Differential Regulator on the side. I have a feeling that may have gone bad. It’s an HT engine code 1.8l
I have a weird fuel pressure regulator. It has one hose going to the air box. A banjo bolt line going into the fuel distributior and at the end a screw fitting going to the fuel return line. This is an HT engine if that helps.
Update* I stuck a 15k resistor in the coolant temp line and took an amp meter to the wires into the Differential Fuel Regulator I was getting 20-30 ohms and with the fuel pumps and ignition on on I got 0 for current. Pretty sure it’s shot.
