Topic: G135EPB 8v GTI (Read 53541 times) previous topic - next topic
Re: G135EPB 8v GTI
Reply #240 –
28/02/26 – Bedford Autodrome Trackday
The day before washed, fluids and nut and bolt check.
Early start at 5am. I got up, walked the dogs, forced some food down and then met Dan and Dion at Tesco to get fuel and grab some lunch for later.
We had a steady 65 mile drive, 1hr 30 in the wet. The forecast suggested it might dry out later in the afternoon so we were hopeful conditions would improve.
After signing on and getting the driver briefing out of the way (with a bacon sandwich) we went out for some very wet sighting laps. At that point it was clear I wouldn’t be making full use of the R888Rs.
Initially I considered waiting to see if the weather improved, but it looked like everyone else had the same idea so I decided to get straight out on track.
Grip levels were exactly as expected in the conditions, but it was still great fun. After a 15 minute session I came back in to check the car and tyre pressures. I was surprised to find they had climbed to 35psi, so there was clearly still a decent amount of heat building up. I dropped them back down to 28psi and went straight back out for more laps.
As the day progressed the rain started to ease and grip levels gradually improved. Bedford is a very forgiving circuit with lots of run off, which gave confidence to start pushing harder and explore both my limits and the car’s.
That said, I did manage two spins in one lap 😳, so I decided it was a good moment to come back in and rest.
Unfortunately a couple of issues began to appear:
A rhythmic grinding noise and what felt like fuel surge on sharp corners.
My first thought was that the grinding noise might be an inner CV joint, I’d brought spare driveshafts with me so carried on. The fuel surge could also have been due to being down to about ¼ tank of fuel, so I brimmed the tank and went back out to get as many laps in as possible.
As the day went on the Mk2s were definitely starting to feel the strain:
Dan' 20v melted the clutch line O-ring at the master cylinder
Woz' 20v had his turbo oil return pipe come loose and start leaking
Dion's ABF had fuel cut issues too, which were cured by topping up the tank
We called it a day around 4pm, which was a shame because the track was really starting to get grippier as the conditions improved.
I managed to get some laps in with Dan and Woz, both following them and passenger. The 20v cars are a lot of fun — the low down torque makes them feel very different compared with the ABF.
That said, I did follow Woz for a couple of laps and managed to keep him in sight — though the weather probably helped level things out!
One questionable highlight was the marshals waving signs at us for “NO DRIFTING” and “STEADY” 😂
I also managed to get black flagged twice:
Once when I drove down a bit of closed track with hazards on when I first experienced the fuelling issue
The second time was for noise — 1 dB over the limit
Despite the weather, the car was surprisingly good fun in the wet, especially with the lift-off oversteer. I feel like I’ve learned a lot from back to back wet trackdays at Donington and Bedford. I did 240 miles of which 130 were drive there and home. So must be something like 110 miles covered on track so approx 29 laps covered.
Post-Track Inspection
We all limped home and compared lists of repairs needed.
Having had the car up on the ramp since:
Nearside ball joint definitely needs replacing
The grinding noise has now been diagnosed as an input shaft bearing 😞 noise can be heard when I gear with shafts disconnected.
As for the fuel surge / misfire, I initially suspected the fuel pump assembly, as it seemed to happen during long corners. However, the fact that a brimmed tank didn’t fix it makes me think it may actually be related to the TPS or throttle switch wiring.
When I unwrapped some of the loom tape I could see exposed copper, so I suspect there may be a short or broken wire somewhere.
Gearbox Decision
It briefly crossed my mind to just find another gearbox, remove the Quaife LSD and sell that on, then treat gearboxes as a bit of a consumable item since they’re relatively cheap and plentiful.
But realistically that would be a step backwards at this stage, so the plan now is to:
Order a full bearing and seal kit
Remove the gearbox this week
Head back to Dan’s to replace the bearings and rebuild it properly 😁
I picked up this thick pile carpet off a mate whi was having a clear out. So might get this fitted whilst the car is off the road. I dodnt even know this was a thing?
Re: G135EPB 8v GTI
Reply #241 –
I've never heard of a thick pile carpet before! Sounds very Gucci!
Also, glad I didn't go now, if you were one db over the limit, I'd have been bollocked on my first lap!
Re: G135EPB 8v GTI
Reply #242 –
I’m keen to pull mine out just to see if there’s any difference at all.
Haha do you think yours is louder than mine? I don’t seem to have issues anywhere else other than Bedford, but I know where the sound meters are so I can normally just be a bit careful.
Gearbox Out
Gearbox out time. Might be straightforward for some, but I’m still somewhat mechanically challenged! To be fair it’s been in and out enough times now that it’s getting easier. The only real struggle was twisting the cup past the flywheel, once I removed the cup it came out pretty easily.
I timed myself — 1 hour 40 minutes.
While I was there I replaced the slightly suspect ball joint.
It’s a bit oily in there I think my rocker cover gasket is still leaking.
The ball and socket on the clutch fork looks OK to me.
Fuel System Check
I can’t remember the last time I changed the fuel filter — probably five years ago. So I fitted a new MANN filter.
I took the cover off the fuel pump and discovered the breather pipe has a bolt stuck in it!
Not sure what the logic was there, but that’s going to get vented properly when the new pump goes in as i cant see that its helping matters.
Wiring Loom Inspection
Started unwrapping the loom to inspect it and… diagnosis is a bit crispy.
There are a few sections like this that don’t look too healthy, so I’m not sure if this could be contributing to the intermittent running issues.
Gearbox Oil
Drained the gearbox oil and it definitely had some glitter in it, which isn’t encouraging.
For now I’ve left the car like this. The engine is sitting on one mount and supported with some wood.
Next Steps
The gearbox is now at Dan’s garage and the rebuild kit is being delivered today. Hopefully we’ll get it stripped later this evening and have a better look at what’s going on inside.
Still need to order:
75W-90 GL-4 gearbox oil
Heat shielding for the loom where it runs past the exhaust manifold
My new fuel pump is also on the way and I’ll sort the tank venting properly when that goes in.
If all goes well I’m hoping to have the car back up and running by the middle of next week. 🙏
Re: G135EPB 8v GTI
Reply #243 –
Went to help strip my box down at Dan’s but hr had already beaten me to it!
The input shaft bearing is definitely worn, which would explain the glitter in the oil. That’ll teach me for cheaping out and not having it fully rebuilt when the Quaife was fitted.
The rebuild kit arrived today, so I’m hoping to start cleaning everything up and get it back together this evening.
Also taken delivery of my new fuel pump and I cut some sections out of a spare loom at Dan’s to repair the crispy wiring I found the other day. That should keep me busy tomorrow!
Re: G135EPB 8v GTI
Reply #244 –
I swapped the pump over the other day. I was hoping to see something visably wrong with the old one but other than looking old it appears ok. I did notice the breather pipe was blocked with a bolt so this needs routing correctly.
Here is the new an old pumps side by side. I might of just wasted £70 here but i'm willing to take my chances! I will hang on to the old pump for now, if my fuel issue disappears i can refit old pump to see if it returns to pinpoint the issue.
New pump in. The old clips seemed impossible to redo up so i've fitted some jubilees but will get some replacements.
i got some connectors and loom off another mk3 hoping to use to replace some of the wiring that goes to my throttle body switch and other wiring that goes past the exhaust manifold. I ordered a de-pinning tool and practiced on the off cuts and seemed pretty easy to use.
I looked at de-pinning the loom on the car but i could see this getting out of hand very quickly! So decided to cut away the damaged crispiness and join them and see how that goes
heat shrinked
and doubled insulated
i taped the loom back together and wrapped some heat resistant sheathing over to give some sort of protection
i over ordered on this as scaled price made better sense so wrapped it over the brake pipes also. there is some excess so may as well put some over the clutch line too. Probably overkill but better that nothing?
Went back round to Dan's to start replacing some bearings in the gearbox.
Some of the old bearings
Started by replacing the easier ones on the casing
We couldn't find the right puller so had to leave it there for now but hoping to get the rest of the bearing done and all built backup before the weekend so i can refit and test!
Re: G135EPB 8v GTI
Reply #245 –
A couple of steps closer last night.
A big puller was borrowed to get the gears apart so we could reach the bearing near the bottom of the gear stack. I didn’t think it was going to come apart, but after applying a bit of heat it suddenly popped — scared the living poo out of me 😂
Next job was to clean this all up and not cock the order up!
Ran out of time again, but despite there being no photos, it’s now back in one piece. The box is basically ready to be rebuilt properly, apart from one bearing in the casing that still hasn’t been done yet.
I doubt I’ll get the chance to finish it over the weekend, or even next week, so for now I just need to sit patiently and wait for some spare time that lines up with Dan as well so we can get it finished off.
Re: G135EPB 8v GTI
Reply #246 –
That looks terrifying!
If I tried that, all I'd end up with is a bunch of fancy coasters!
Re: G135EPB 8v GTI
Reply #247 –
haha hope thats not the case for me! Amazing how confidence inspiring it is having someone doing it with you thats done it many times.
A couple more photos before refitting
Aslo bought a vibra-technics front engine mount to try. Initially liked it but the harshness soon wore thing and back to OE!
As you can see the gearbox is back in. Keep forgetting to tilt jack the car higher so that the gearbox doesnt hit the chassis leg! So again took me far too long to refit.
Some Millers gearbox oil 2 litres put in although will top up to 2.1!
Made a mistake! Fitted the wrong bolt on the front cable bracket. It was too long and fouling the clutch fork, had  mild meltdown fearing something was wrong and all the hard work on the box was in doubt.
Correct one found
So the box went in and went for a test drive, couldn't believe the noise was still there! 😭 I used Dan's driveway as a ramp, we took it in turns to lie accross the engine driving down in gear, out of gear, clutch in and out, engine on and off fearing the box. We were about to try a spare 02j that was lying around when Dan said it sound s bit like something is dragging. When i looked under the car i remembered... the exhaust heat shield had come detached at Bedford and i had cabled tied it back up temporary and hadnt cut eh tail off the end of the cable ties. These were dragging on the floor! Cut them off and the noise went! Absolutely unbelievable 😂 rebuilt a gearbox because of two cable ties i hadnt cut the ends off. Still the input shaft had proven to be rough and I have a future proofed box now.
Amazing difference. 2x 15x7 rims both with 195 50 tyres. The Accelera is so much skinnier than the R888
Track wheel coming off
Road wheels back on
Re: G135EPB 8v GTI
Reply #248 –
Yeah, I was super disappointed with the Acelleras when I saw the width compared to my old NS2Rs.
Re: G135EPB 8v GTI
Reply #249 –
June/July 2026 – Bedford Autodrome and More Repairs
Following the gearbox f**k-up, I booked a day at Bedford Autodrome with Dan in his 20v.
As usual, we made an early start, meeting at Tesco for a meal deal and fuel before cruising over. Obligatory car park photos!
And a few from the day
Dan managed to snap one of his rear arm bolts. Luckily, the on-site workshop had some high-tensile bolts in stock and kindly helped us out.
I also had a few passenger laps in Dan’s 400+ bhp 20v. Not much was passing him all day!
A couple of the professional photos:
Looking at the photos, I think some stiffer front springs might help reduce the body roll. However, I don’t want to compromise it too much for road use, so it needs to remain a sensible balance.
Dan’s car only suffered the snapped bolt, which was fixed quickly, and mine was good all day. My oil temperatures were a little higher than I would have liked, although it was a hot day. I might look into fitting an oil cooler further down the line.
After we packed up and started driving towards the exit, I noticed the steering wheel shaking from side to side quite aggressively. We stopped, jacked the car up and discovered that the front-right wheel bearing had given up. The driveshaft flange nut also seemed to have worked loose. I tightened it up and, rightly or wrongly, carefully limped the car home.
When I started stripping it down, I couldn’t remove the track-rod end for the life of me. In the end, I chopped it up and pressed the remains out.
With a fair bit of effort, it eventually came out.
The DS2500s didn’t look too clever either. This is now the second set that has done this to me!
The wheel bearings were also extremely difficult to remove. I eventually gave them to Dan to do at work, and it took 12 tonnes of pressure to get them out.
New bearings and drive flanges fitted on both sides:
Wheel studs correctly torqued and secured with Loctite
Mintex M1144s came recommended as a good alternative to the Ferodos, so I decided to give them a try.
I also raised the front BCs by a few millimetres. I had noticed a small amount of tyre scrubbing through hard left-hand corners, and this was the ideal time to sort it because the alignment would need redoing after replacing the bearings anyway.
July 2026 – Mk2 Owners Club National Meet at Curborough
Next up was the Mk2 Owners Club National Meet at Curborough Sprint Course near Lichfield.
I go every year and it’s always a brilliant weekend. The people I originally met through the club have now become friends, and it’s a great opportunity to drive the car to its limit in a relatively safe environment.
Plenty of passenger laps were given and received. It never gets boring seeing people’s reactions, and it was nice to receive a few compliments about the car along the way.
No prizes for me again this year! They went to Dan and Woz, and both were thoroughly deserved.
My car behaved perfectly all weekend. The new Mintex pads have a really strong initial bite and I’m very impressed with them so far. Hopefully, they’ll also last better than the DS2500s.
I made a couple of minor alignment tweaks on Saturday, but otherwise I just drove it within an inch of its life all weekend and it didn’t complain once. I’m very happy to have seemingly overcome all the self-inflicted problems!
The plan now is to enjoy the car while the summer is here before deciding what comes next over the winter.
Back to the weekend itself, driving Dave’s 3.2 was a massive highlight for me. I also took Ash’s track-prepared ABF out, which was wild. It’s a seriously fast car considering it still has a standard engine and gearbox with no LSD!
Woz last minute repairs
Helmets made mandatory even for cars without cages now
Pushing Dan back to the pits after he snapped a driveshaft. He had to drive home to collect spares, but returned, repaired it and continued racing for the rest of the weekend without any further problems!
Mine and Da's with Paulina's 3.2 Corrado in the background
Parade lap
BBQs and bonfires and a few quiet beers to wind down in the evening
Cheeky Rallye came along
Another brilliant National Meet and a faultless weekend for the Golf. After all the recent self inflicted problems, it felt good to just drive it hard and enjoy it again.
Re: G135EPB 8v GTI
Reply #250 –
25th September 2026, Bicester Motion
I booked another trackday! This one was at Bicester Motion through Oli's Secret Trackdays. It's only a small track and was just the afternoon session. They ran it anti clockwise for the first few hours and then swapped it round to clockwise. It was a low numbers day, around 20 cars I think, so there was plenty of track time to be had.
Me, Dan (20v), Woz (20v) and Tom (abf) had all booked on, along with a fella called Tan in an Oak Green 3.2, so there were five Mk2s between us. There was also a Mk1 there which was very similarly matched to my car, which made for some good fun on track.
I managed to get some tuition from Oli. He started by saying "you can drive" 😏 but then followed it up with plenty of advice, which I tried to take on board for the rest of the day.
https://youtu.be/ZIggkDVICp0?is=M6kHjUHO3x7nFL9d
It wasn't a problem free afternoon. I think pretty much all of us had an issue of some sort, but we all managed to drive home in one piece, which is the main thing!
Mine came away with a couple of jobs. The front subframe is very crusty whichbi already knew about, so I've got a powder coated Mk3 subframe and a new old stock mount lined up to replace it. The rear exhaust hanger has snapped the stud, so that needs welding back on and the speedo stopped working. I'm assuming the speedo cable has either broken or come detached.
Dan's heater matrix blew up and he also lost his fans. Woz somehow managed to lose two of the three bolts holding his gearbox bracket on. The final bolt then sheared off and took a chunk of the gearbox casing with it for good measure 😳
So not exactly a trouble free trackday, but plenty of track time, laughs and all the cars made it home under their own steam. By old VW trackday standards, I'd probably call that a success! Definitely recommend Oli's Secret Trackdays and will book through him again in future.
Oh yeah, the photographer was class 👌🏻
Re: G135EPB 8v GTI
Reply #251 –
I had the same issue with the rear exhaust bracket bolt the week before the national meet this year!
Re: G135EPB 8v GTI
Reply #252 –
sign of their age.. falling apart 😅 did you weld a nut on in its place?
Re: G135EPB 8v GTI
Reply #253 –
I made a little plate and welded a bolt to it, then welded the lot to the hole that the original was sat in! ;D
