Topic: Door drop (Read 1860 times) previous topic - next topic
Door drop
Hi, I have a 3 door and it seems the door does not close very well due to lock not aligning correctly with the catch.
I presume this is from years of abuse by a driver leaning on the door to get in or out.
At the moment I can shut the door with either a gentle slam or have to lift the door as I close it.
I need to lift it maybe 1cm if that.
Anyone know a good way to get the door back to the correct alignment?
Thanks in advance
Re: Door drop
Do the door pins bend? Just wondering if it will be noticeable before removing the door?
Re: Door drop
Try lifting the door when its slightly ajar you should see where the play is.
Re: Door drop
It's usually the bottom pin that wears. If you decide to replace it, replace the half hinge as well. Be aware you will need to use a reamer on the hinge half as the pin will be too big. A temporary fix is to put a washer between the top hinge and door.
