Topic: Build date from vin (Read 1409 times) previous topic - next topic
Build date from vin
Hi, am trying to find the build date of my 1985 mk2 as it possibly could be able to register it for classic status (no longer have to pay VED)
Thank you for any advice.
Trying and mostly failing to keep a rust old tart of a golf on the road.
Re: Build date from vin
See here;
https://www.golfgtiforum.co.uk/index.php?topic=97462.0
I would think you need the year code of your car to be E, which would put it as a 1984 build. If first registration date is prior to 8th January 1985 then that also means you qualify for zero tax
See here;
I would think you need the year code of your car to be E, which would put it as a 1984 build. If first registration date is prior to 8th January 1985 then that also means you qualify for zero tax.
I was hoping my mk2 was built late 1984 as it was registered March 1985 but unfortunately I don't think  this is the case.
Bummer never mind thank you for the reply.
No problem. You only have to wait one more year!
