Topic: Exhaust Manifold (Read 2134 times) previous topic - next topic
Exhaust Manifold
Evening all,
I looking for some advise on my options for a replacement exhaust manifold as mine has a fairly large crack in it in the most inaccessible place so not sure it can be repaired!
I have an ABF conversion which is using manifold part number 027253033AD, I've messaged Matt @ MK2 Spares to see if he has a good direct replacement in stock so waiting on an answer back on that one and I've also looked on the tinterweb but this manifold doesn't seem to be that easily available so my question is what are my other options?
I ideally want to replace like for like as I'm not looking for any performance improvements and that way I know it will fit, has anyone out there had a similar issue, if so what was your solution?
Thanks
Re: Exhaust Manifold
Also on this subject,
Does anyone know the significance of the 2 letters at the end of the part number as I have seen various manifolds on the internet with the same main part number (027253033) but different letters at the end AB/AT/BC etc etc?
Thanks
I'm not sure about the stock manifolds, but if you get really stuck, you can fit any 16v manifold to an ABF with a little work.
As for the letters at the end of the part numbers, they're usually for variants of the part.
Usually start off with no letter, then go through the alphabet every time there is a revision.
Technically, it should fit as long as the main numbers match.
Thanks for the info Monkey, much appreciated.
Another member who lives not that far away has got in touch to say they have an AT numbered manifold so I'm going over on Friday to compare mine with that one, fingers crossed it's usable.
I'll let people know the outcome for future reference.
So as promised I'm back with an update,
I can confirm that part number 027253033AT is a drop in replacement for 027253033AB. The replacement manifold is in with no issues so far.
Installation was easy enough just like the removal of the old one. I took the manifold and downpipe out as one, there was a little bit of jiggling needed but it wasn't too much hassle. Fitting the replacement, also with the downpipe attached, was just as easy.
