Topic: New member (Read 1104 times) previous topic - next topic
New member
Good evening all
New member from perthshire Scotland.
Looking to get a project golf, maybe do a wee engine conversion had a couple of mk2s back in the day!
Cheers
Re: New member
Welcome and Good luck with your search
Re: New member
Welcome along!
Love engine swaps. What one are you looking to drop into it?
Re: New member
Welcome along!
Will do a bit of research on the site first but I have a 2003 tt just now with a bam engine, so im thinking about putting that in
Re: New member
Not a bad engine to use!
I've written a 20v guide on here, it's quite old, so the cost is probably out, but the method is still the same.
Re: New member
Fantastic that's the very reason I joined the forum to get everyone's hints and tips!
I'll have a good study through your guide!
Re: New member
No problem, here you go...
https://www.vwgolfmk2.co.uk/clubforum/index.php?topic=129.0
Re: New member
Great guide, plenty food for thought. Think I will go for a mk3 subframe and fuel tank as well, seems to make things a bit easier. Will probably look at some plug and play wiring any recommendations??
I did think about air con but after reading ur other guide I think I might give that a miss
Re: New member
There are a couple of people who do plug and play options.
If you go on the facebook group, most of them are on there, put a shout out and I'm sure someone will come to you.
And the air con was a rather large ball ache, but ultimately worth it.
Was lovely driving around this summer with the windows up!
