Topic: Golf Driver 1600cc 1990 carburator top cover ( airbox) (Read 1003 times) previous topic - next topic
Hi, I'm new and this is my first post :)
I have a 1990 mk2 golf driver 1600cc cab 55 Kw EZ 75HP , just before the 1800cc came out.
I've been doing my head in about 2 little things and hope someone can confirm, TY.
First, on the plastic cover that fits on top of the cab, mine doesn't have a round joint in between the part that fits on carburetor ( round). Is this normal ? i made loads of research and seems it doesn't have one from factory and usually is for 1.1-1.3 models only ?
Second the air filter housing secure rubber at the begining of the hole airfilter box is broken and i'm lookimg everywhere for a replacement. This model has one that only screws on one side and then the other side is a metal curved ring that fits and holds on the airbox ring. All i could find is the standart one with two threads that of course will not fit ! Any ideas where i can buy this ?
Thank you for all your advices,
Phil.
Re: Golf Driver 1600cc 1990 carburator top cover ( airbox)
Try posting a photo. I can’t make sense of your post.
Hi, ty, yes i knew it was a bit confusing. So first picture is what i bought on e-bay, problably wrong, as you can see, it's got a joint inserted in the cab cover, mine doesn't and seems it does not need one for a Golf mk2 Driver ?. The second pic is about holding the full  airbox. I got this part but it's not the right one as it's got 2 screws,... And mine only got one with the rubber as per photo of what i need ?
 if it makes sense ??
Sounds dumb but how can i dowload pics in here ? I have no clue ty
i meant from my pc as all i can see is insert an image option and it doesnt's want to post? Thank you.
To post a photo you have to save the photo on a hosting web site, then post the web link.
Thank you very much ! I shall do this shortly,...
I trust i did it right this time and hope you will be able to rest my mind on these small issues. Thanks again, Phil.
Note the metal clip holes the back piece to the top of carb. If you have a Weber, it bolts on to the carb through the small round hole. The front piece clips to the rear piece and the rubber bit bolts to a metal bracket
thank you all, as i said all the pictures are from the hole part i bought on ebay as i needed a few compatible bits, not actually mine.
My car looks 100% as the photo you posted Keekster64. The second photo aslo from e-bay and noticed the rubber ring in it. Mine doesn't have it so it's normal as i got the orginial pietsburg cab as explained again by Keekster, thank you again !
Finally, i looked everywhere for the piece with the rubber that holds the front of the box ( picture 1 ). Where can i buy it if possible ???, i looked everywhere and ended getting picture 4. I guess i could always cut one side ?
Thanks again, Phil.
