Topic: Rubber Jack Pads... (Read 1778 times) previous topic - next topic
Rubber Jack Pads...
Bought one on ebay a few years ago and in fairness it's lasted quite a while.
The trolly jack it was for was one of those cheapy 2 tonne red things with the swivelling metal affair within the lifting cup.
You can remove that and put the pad in it's place to save your paintwork... fits exactly.
Anyhow, it finally started to split because the sills on the 205 are quite sharp and they began to dig into it.
Quick look shows pads are around the £4.00 mark - with some quite a bit more if you're mug enough not to look around before buying.
In case you haven't seen one up close they're actually made from 6oz. ice hockey pucks... some pads are lightly machined to give a slot, but to me that just decreases the thickness (ie. strength).
Cheapest pucks at the moment, also on eBay - 10 for £14.99 inc. P+P.
Re: Rubber Jack Pads...
Got a couple of them here! Do the job well! 👌
Brilliant, I’ve just put one in the basket from the above link. Just what I’ve been after. Cheers
