Topic: Insulation (Read 1878 times) previous topic - next topic
Insulation
Just wondered what people use to replace all the original insulation upon restoring-eg. Under roof lining etc.
Also what can I replace the foam seal around the door closing /light stitch detector with?
Re: Insulation
Thanks for that, hadn’t come across it but I’ll get straight on it now 👍
Re: Insulation
Heritage do sell some made by SSP, there's also a guy in Germany (though might prove to be too expensive now) who does his own and because of that probably a bit more like the originals if that's important to you.
I've an image of them together, will post it up when I find it.
Re: Insulation
Spoke too soon... The Heritage ones now seem to be the same profile as the German guy's, wasn't always the case as you can see from the piccy of those previously available below - If you're getting them elsewhere than Hertiage, and it matters, may be worth checking which style is being supplied.
https://www.ebay-kleinanzeigen.de/s-anzeige/golf-2-tuerfangband-dichtungen/1585027709-223-3059
https://www.heritagepartscentre.com/uk/867837267-door-check-strap-seal.html
Re: Insulation
Thanks buddy that will do fine, just some insulation now 🙄
