Topic: brake pad types (Read 3126 times) previous topic - next topic
brake pad types
i've got TRW GDB454 brake pads:
VWA: 20887, 20888 (part numbers ?). It's for models from 08/83 till 12/92.
YM9805 and PR4154 has been written by hand on the packaging.
the mechanic, who unstucked my screws, said i fetched the wrong brake pads.
according to him, there are 3 types for mk2's.
is somebody around here, who can tell me more about those types ?
are they related to the strength of the engine ?
Re: brake pad types
Depends on the model of car.  For the lower spec models there seems to be two types. The earlier type has 10mm (solid) discs and pads to suit, the later cars (VWII calipers) had thicker 12mm (solid) discs.  Its easy to tell which calipers you have, just check for VWII written on the caliper or measure the width of the disc.  I'm not sure about the higher spec models, such as the 16v GTi or G60, but someone else will know.
Re: brake pad types
the VWII inscription and the brake pads,
suiting the brake discs (why ?) were new to me.
thank you. together we will probably sort this.
i've seen 12mm discs on the 90 hp and 10mm discs on the (rather new) 55 hp
and it's said the calipers should match each.
but on the 90 hp, i have brake drums on the rear,
so, given they are matching, i could only use the two on the top of the picture.
a gti probably has 20mm air-vented discs and matching calipers. right ?
edit: or was it 22mm ?
Re: brake pad types
My understanding was the GTi has the same VWII calipers, but the pads were thinner to incorporate the vented disk.  I bought fresh pads and 12mm discs from VW heritage, after checking the calipers were VWII.  VW heritage list 'pads for 12mm discs', so I guessed there were slightly different to the pads for the 10mm discs.  I also have drums on the rear, but being a 1600 it doesn't have the brake compensator valve at the rear.
Re: brake pad types
According to 7Zap https://volkswagen.7zap.com/en/rdw/golf/go/1991-110/6/
With callipers:
191 615 123 left and
191 615 124 right
Part number for pads: 191 698 151 E
are for front
239X10MM-4/100
37KW-40KW
and with calliper:
1H0615123C left and
1H0615124C right
Which are VW II callipers
Part number for pads: 1H0 698 151
are for front
239X12MM-4/100
40KW-82KW
37KW-77KW
and using the same callipers
Part number for pads: 191 698 151 L
are for front
GIRLING
239X20MM (Vented)
79-82KW
This covers base spec to 8v GTI.
16v GTI uses a different hub and calliper set up to give 256mm vented discs.
As @Keekster64 says 8v GTI pads for vented discs are the same as for solid discs but with less friction material making them thinner.
Any of these pads should fit in the callipers, it's just the thickness of the disc that changes.
