Topic: Test your knowledge! (Read 94115 times) previous topic - next topic
Re: Test your knowledge!
Reply #150 –
K-Jet is my weakness, I've only ever had 2 k-jet cars and they both worked fine, so I never had them apart!
Reply #151 –
Well as I know Tim has been knee deep in K-Jet in his old mk2.
I'm going to say something to do with a piece of test kit that sets up K-Jet.
That's what led me to the part, an internal part to the WUR.
It's on the inside, does it hold the metering head to it or something.
We have a winner, more a case of deduction I think that actually recognising the part in this instance.
But yes it's a pic from when I took a Warm Up Regulator (WUR) apart. Unfortunately when I cropped the image I over wrote the full image and can't find the original.
There's not a lot inside a WUR, there's sort of a diaphragm based valve and plunger with a biometric strip that bends when a current is sent through it, as things warm up. As it bends the strip pushes against this disc and closes the valve reducing the flow of fuel through it. The theory being the car needs more fuel to get it started and while it comes up to temp.
Reply #152 –
Good one!
Reply #153 –
Bugger I should have known that after running a modified one on my MK1 Campaign, cracked a few open, I thought the disc was bigger in the picture, unfortunately I have a good working knowledge of the whole KJet system after replacing a system after a MK1 filler neck decided to dump rust in the tank clogging the whole system.
Reply #154 –
I don't know for certain if it's the only one in the car, certainly haven't come across another, but don't take that as gospel.
It's (mine at any rate) is the dark green colour that it appears to be in the image.
Reply #156 –
I know  :-X
Reply #157 –
Just checked on 7Zap and I think it's for RHD cars only (in this particular size anyway) has its own part number and nearly sure now that there's only one of them.
Reply #158 –
I've only ever seen one on a car at a time.
Reply #159 –
Go on... you're busting to say what it is - you're not barred anymore!
Reply #160 –
Only thing is, I don't have anything to offer up at the moment.
I don't want to 'brake' the flow...
Reply #161 –
well I was thinking it's very similar to the clip that goes where the front flexi-brake hose meets the ridged hose and monkey's 'brake' hint has cemented that idea. however there's one of them on each side and this is sightly different.
But I can see there's a circle one side and the flip slide of the clip is an open U.
So it's something brake system related but I haven't really done that much with the brake system.  Assuming it's along the same 'lines' as the flexi to ridged retainer it is a similar clip at the rear beam end? I still imagine there would be 2 though?
Reply #162 –
Yes, brake related but in the sense that, that includes every aspect of the system.
There may be very similar or even the same style of clip elsewhere, but this one seems to be a unique size - even the LHD equivalent is slightly different dimensions.
Reply #164 –
Getting very hot.
