Topic: Test your knowledge! (Read 91689 times) previous topic - next topic
Re: Test your knowledge!
Reply #255 –
Yes... but extra kudos for giving this particular versions location, there's a few different types (on my car at least).
Reply #256 –
I believe they are attached to the headlights to hold the corner of the grill tucked in
Reply #257 –
That's it...
Reply #258 –
Well done Sli.
I should have known this from modding the slam panel earlier this year!
Reply #259 –
Another penalty kick, reading a few recent posts suggests some of you should be familiar with what this is part of.
It would originally have been zinc plated, mines had a session in the phosphoric acid bath.
Reply #260 –
Does this go around the gear linkage to stop the ball dropping off, or something like that
Reply #261 –
Described as a 'guard plate', but yes, it clips on to the gear shift gubbins in the engine bay.
Reply #262 –
Both fitted in close proximity... may well be other similar items elsewhere on the car, maybe even doing a similar task, but these are specific to somewhere in particular.
Reply #263 –
That is definitely a 50p coin
Reply #264 –
Cut backs... would've been a £1 coin a few months ago!
Reply #265 –
the inserts in the fuel pump rubber mounts?
Reply #266 –
No... but they are very similar and in a roundabout way do the same job, just bigger.
Reply #267 –
Do they come in the gear linkage repair / bush kit.
Reply #268 –
Getting warm, I'll give it to you if you're specific.
Reply #269 –
they are the insets that sit in the cap in the remote box, and fasten to the same.
