Topic: Test your knowledge! (Read 94131 times) previous topic - next topic
Re: Test your knowledge!
Reply #360 –
Not going to get a picture at this time of night. When you pull the hand brake on the cables turn a shaft on the back of the callipers. That small piece of metal sits in an offset hole in the shaft and pushes the piston and pads against the discs as the shaft turns.
Reply #362 –
Never seen it before
Reply #363 –
I'm becoming too obvious, have to stop using things that are connected with other posts.
Yes, heater box again. Sit in recesses around the ends of the flap spindles, on the outside.
Reply #364 –
This is an easy one if you, like me, have broken one.  However they don't often break:
Reply #365 –
This one is frustrating, as I'm sure I've clipped them on as I've been fitting the trim, but can't for the life of me remember exactly where!
Reply #366 –
Yes they secure a trim panel. Just one edge of the panel is secured by several clips.
Reply #367 –
Likewise, thought the sill trims but they are white plastic, maybe one is metal?
Reply #368 –
MK1 door cards use these clips I believe
Reply #370 –
Yes that’s the one. Sunroof panel, it pushes up and clips into the steel roof
Reply #371 –
Should have figured that out, mine is out of the car
Reply #372 –
Found this on the cave floor. anybody know what it is where it should be?
Reply #373 –
Found one just the same between the carpet and underlay of the front passenger side footwell.
Had dried up and come off, but presumed from the way it was facing it was originally stuck to the carpet.
Reply #374 –
I thought L90E would get this one, yes indeed it is a carpet manufacturers QA sticker.
