Topic: Test your knowledge! (Read 94113 times) previous topic - next topic
Re: Test your knowledge!
Reply #450 –
Is it a grommet with cavity wax in it?
A hollow shaft end plug with grease in it?
Reply #451 –
yes, it seems to be cavity wax and half of the tip is hollow.
do i need to make more pictures ?
Reply #452 –
I would say a very clear picture with a tape measure along side to get an idea of the size is needed.
I think I know what it is but I've never seen one like that on my car.  I have blanking grommets with cavity wax in them but not from inside the car. Hopefully somebody how has done a full strip down will recognise it.
Reply #453 –
the sun came out and helped a little :-)
one square of this math-paper, on which i have place the part on, is half a centimeter.
some measures are: height 13 mm, disc-diameter 23.5 mm, bolt-diameter 15.5 mm.
Reply #455 –
i can not find it. where does cavity wax reside ? has it to be the door
or maybe behind the dashboard (recently un- and refitted) ?
maybe someone comes across at some point.
as a general test your knowledge mk2 plastic part, i put this:
Reply #457 –
it can be found in the surrounding of the wheelhouse.
i removed it while preparing a welding job in it.
Reply #458 –
not a slider, the thing is a round, hollow tube, open on one side.
Reply #459 –
Is it the bung you put in the bumper guide to hold it on?
Reply #460 –
@Monkey not quite: similar design, but black, edgy tip and wider, i guess.
i found it residing in the corner of the cavity on the right from this vertical grove
and pointing, with the round, closed tip, to its edge (picture from @Eddypeck 's thread):
could it have been for aligning the sheets, before the welding robot fixated them
(but there were no burning signs on the part) ? other possibilities ?
Reply #461 –
I see what is going on, @mk24ever you are supposed to know what the part is. You post a picture as a challenge to us. We guess, you post clues, somebody identifies the part or you advise what it is.
Let’s see if we can identify your part though, there is a chance that it is not a MK2 part. Could you post a picture of the open end please?
Reply #462 –
When I first saw it it looked like a plastic wall plug I'd have rattling round the footwell after doing some DIY at my Mum's 😁
Not sure I've ever unearthed one of those on my car.
Could it be a drain tube?
Reply #463 –
@AndyBa i also thought about draining, but with the closed end..
@PWardy you are right and more so with the previous two items.
thank you for helping and explaining.
sorry to everybody for abusing the tread, but as suggested, i'll finish this up.
there comes the pictures
(i used my radio support spigot as cap support):
Reply #464 –
Transit cap for fuel pipes, keeps dirt out prior to fitting.  Can't imagine how it got inside the wheel arch though.
