Topic: Test your knowledge! (Read 91688 times) previous topic - next topic
Re: Test your knowledge!
Reply #61 –
Looks like a valve to me
Reply #62 –
About 3cm across and 1.8cm deep.
Not a valve.
Reply #63 –
is the disc in the centre metal or plastic, hard to tell if it's textured plastic or pitted metal. I can see the surround is plastic, does the centre move within the surround?
There's something familiar about it, some sort of cover cap or blanking plate ..... grrrrr
Reply #64 –
It's actually a new one (sealed and good brand) and like you I thought the finish was a little off.
The 'disc' is metal and will turn under thumb pressure... not a cap or blank.
Reply #65 –
I was going to show you a photo of the reverse side as it's noticibly different, but I can't find the thing anywhere... set it down and it's evaporated
Instead, by way of your 24 hour clue - it's situated in the engine bay area of the car.
Reply #66 –
Is it engine based, or engine bay based.
i.e. is it on some engines and not others?
Reply #67 –
Wouldn't like to commit and say it's from some types of MK2 and not others as I don't know - I got it for an 8v PB
It's an internal part.
Reply #69 –
Is the whole thing fitted?
Or is the plastic part something to just hold it together in transport?
Reply #70 –
As far as I'm aware that's how it's fitted... sly_gti knows what it is, without giving to much away he could maybe confirm that.
@sly_gti
Reply #71 –
Found it... intentionally took this piccie of the reverse side a little bit further back. Didn't want to make it too easy and you see any numbers etc., but didn't plan it to be just so blurry, sorry.
Reply #72 –
Whole thing is fitted, though I've never actually replaced one
Reply #74 –
Check out the list of original equipment manufacturers I'm compiling - will give you an idea of the areas I've been working in - one in particular is very relevant.
