Topic: Test your knowledge! (Read 94115 times) previous topic - next topic
Re: Test your knowledge!
Reply #405 –
Its the non PAS rack adjusting screw.  Neat and simple engineering adjusts the rack, locks the setting and prevents loss of gear oil.
I had no end of trouble getting this rubbish picture.  This was the best of 5 attempts.  The screw head can be seen in the centre of the closing plate.
Reply #407 –
Interesting, there are a number of parts in this thread that are big bumper parts that are not on earlier cars, or relate to options that became standard.
Hehe. I guess that should have been a clue for the Big Bumper/PAS crew being at a disadvantage!  :D
Reply #408 –
I don’t know, I just thought it is a really cool bit of mechanical engineering. I thought it broken and nearly ran a die nut down it. Thankfully I researched it and was surprised by what I found.
Reply #409 –
Nobody disadvantaged here, fairly certain all 1.6 and 1.8 cars have one of these:
Reply #411 –
Wanted to double check it as its a spare. 7Zap on my phone isn’t playing. So I think, and I may have to eat humble if I get this wrong, shift gear and this bit holds a lever in place.
Reply #412 –
Well this one hasn’t been great. Perhaps I should RELEASE some more clues. Or would that be CLUTCHING at straws?
Reply #414 –
Yes they would be disadvantaged, I forgot MK2s were available with an auto.  Also I guess it's not on 1.0 and 1.3 models either.  I was referring to the big vs small bumper differences, this part is common to both.
Your guess is exactly what I thought would be suggested as soon as I posted the part.  If you follow that cable and levers and push rods all the way to the clutch you will have come across this component.
Reply #415 –
Hmmm, I've not played around with 020 transmissions yet.
It's on the list though, so I expect I'll encounter it soon enough!
Reply #416 –
Yes you will definitely come across it. You don’t even need to split the box from the bell housing. It’s part of the clutch release mechanism.
Reply #417 –
I have a feeling I know what the 02A version looks like, I'll keep my eye out for it now.
Though it feels like a very long way away!
Reply #418 –
Let's call time on this, it's part no 21.  It secures the lever that presses on the release bearing (edit; no perhaps it secures the return spring, it's a while since I did battle with it).
Reply #419 –
This isn't a test your knowledge, just thought you may find it interesting.  This is a 90s DIY security feature that I have removed from my car.  Pressed steel about the size of a Cook's Matches matchbox, but open on three sides.
Any idea what it guarded against?
